We had to flash our Jetsons for compatibility with L4T 35.6.0. We previously used 35.4.1 without any display issues, but with 35.6.0, I am finding that the Jetson cannot connect to the touch panel monitors that we’ve bought. The panels are 1024x600 in resolution, and while it was fine with 35.4.1, when booting with it connected with 35.6.0, the screen shows the UEFI splash screen but instead of going to the dmesg printout and login screen, it just sort of flickers and shows random lines vertically.
Based on the reply I received here.
It does seem to line up with the issues mentioned on this NVIDIA page
Assuming it is in fact a frame buffer console pixel clock calculation issue, what can be done? I tried using the script mentioned in the article and flashing again, but the result was the same with the resolution set to 720x480 and 1024x600. I have contacted the makers of the touch panel to see if they can provide things like the porch and sync parameters to see if that works, but in the meanwhile, if anyone has any other ideas, feel free to let me know.
Here is the dmesg output for | grep display since --level=err only showed display-related issues (and an unrelated error regarding imx219, but I don’t think it matters).
[ 0.980810] tegradccommon 15200000.display-hub: Nvhost Channel map failed
[ 5.823001] tegradc 15200000.display: Adding to iommu group 26
[ 5.823358] tegradccommon 15200000.display-hub: host1x channel mapped
[ 5.823372] tegradccommon 15200000.display-hub: dc_common syncpt # 1 allocated
[ 5.823405] tegradc 15210000.display: Adding to iommu group 26
[ 5.823409] tegradccommon 15200000.display-hub: dma mapping done
[ 5.825434] tegradc 15210000.display: disp0 connected to head1->sor
[ 5.825499] tegradc 15210000.display: parse_dp_settings: No dp-lt-settings node
[ 5.825594] tegradc 15210000.display: DT parsed successfully
[ 5.825600] tegradc 15210000.display: dc.1 probe not in device tree order, deferring
[ 5.827512] tegradc 15200000.display: disp0 connected to head0->sor1
[ 5.860438] tegradc 15200000.display: DT parsed successfully
[ 5.860471] tegradc 15200000.display: Display dc.0000000009228150 registered with id=0
[ 5.899683] tegradc 15200000.display: vblank syncpt # 8 for dc 0
[ 5.909247] tegradc 15200000.display: vpulse3 syncpt # 9 for dc 0
[ 5.922284] tegradc 15200000.display: hdmi: can't get adpater for ddc bus 3
[ 5.933614] tegradc 15200000.display: out->type:1 out_ops->init err = -517
[ 6.268225] tegradc 15210000.display: disp0 connected to head1->sor
[ 6.272902] tegradc 15210000.display: parse_dp_settings: No dp-lt-settings node
[ 6.286644] tegradc 15210000.display: DT parsed successfully
[ 6.300060] tegradc 15210000.display: dc.1 probe not in device tree order, deferring
[ 6.314296] tegradc 15200000.display: disp0 connected to head0->sor1
[ 6.338305] tegradc 15200000.display: DT parsed successfully
[ 6.350193] tegradc 15200000.display: Display dc.0000000079a50ac3 registered with id=0
[ 6.425969] tegradc 15200000.display: vblank syncpt # 11 for dc 0
[ 6.438685] tegradc 15200000.display: vpulse3 syncpt # 12 for dc 0
[ 6.445978] tegradc 15200000.display: hdmi: invalid prod list prod_list_hdmi_board
[ 6.457057] tegradc 15200000.display: hdmi: tegra_hdmi_tmds_range_read(bd) failed
[ 6.477065] tegradc 15200000.display: probed
[ 6.528811] tegradc 15200000.display: fb registered
[ 6.611911] tegradc 15200000.display: dc_poll_register 0x41: timeout
[ 6.620083] tegradc 15200000.display: timeout waiting for postcomp init state to promote
[ 6.671907] tegradc 15200000.display: dc_poll_register 0x41: timeout
[ 6.682292] tegradc 15200000.display: timeout waiting for win assignments to promote
[ 6.682298] tegradc 15200000.display: tegra_nvdisp_head_enable, failed head enable
[ 6.682452] tegradc 15210000.display: disp1 connected to head1->sor
[ 6.694684] tegradc 15210000.display: parse_dp_settings: No dp-lt-settings node
[ 6.694759] tegradc 15210000.display: DT parsed successfully
[ 6.708703] tegradc 15210000.display: Display dc.0000000074f293b5 registered with id=1
[ 6.743781] tegradc 15210000.display: vblank syncpt # 17 for dc 1
[ 6.743793] tegradc 15210000.display: vpulse3 syncpt # 18 for dc 1
[ 6.750408] tegradc 15210000.display: probed
[ 6.827046] tegradc 15210000.display: fb registered
[ 6.860586] tegradc 15200000.display: blank - powerdown
[ 6.864844] tegradc 15200000.display: unblank
[ 6.919901] tegradc 15200000.display: dc_poll_register 0x41: timeout
[ 6.919906] tegradc 15200000.display: dc timeout waiting for DC to stop
[ 6.971901] tegradc 15200000.display: dc_poll_register 0x41: timeout
[ 6.971906] tegradc 15200000.display: dc timeout waiting for DC to stop
[ 7.023903] tegradc 15200000.display: dc_poll_register 0x41: timeout
[ 7.023909] tegradc 15200000.display: timeout waiting for postcomp init state to promote
[ 7.075904] tegradc 15200000.display: dc_poll_register 0x41: timeout
[ 7.075910] tegradc 15200000.display: timeout waiting for win assignments to promote
[ 7.075914] tegradc 15200000.display: tegra_nvdisp_head_enable, failed head enable
[ 7.075938] tegradc 15200000.display: update windows ret = -14
[ 7.075942] tegradc 15200000.display: sync windows ret = -14
[ 7.126327] tegradc 15210000.display: blank - powerdown
[ 7.178701] tegradc 15200000.display: hdmi: plugged
[ 23.850351] tegradc 15200000.display: blank - powerdown
[ 23.850387] tegradc 15200000.display: unblank
[ 23.899970] tegradc 15200000.display: dc_poll_register 0x41: timeout
[ 23.899979] tegradc 15200000.display: dc timeout waiting for DC to stop
[ 23.952072] tegradc 15200000.display: dc_poll_register 0x41: timeout
[ 23.952080] tegradc 15200000.display: dc timeout waiting for DC to stop
[ 24.003924] tegradc 15200000.display: dc_poll_register 0x41: timeout
[ 24.003996] tegradc 15200000.display: timeout waiting for postcomp init state to promote
[ 24.055929] tegradc 15200000.display: dc_poll_register 0x41: timeout
[ 24.055940] tegradc 15200000.display: timeout waiting for win assignments to promote
[ 24.055945] tegradc 15200000.display: tegra_nvdisp_head_enable, failed head enable
[ 24.057652] tegradc 15200000.display: unblank
[ 24.107945] tegradc 15200000.display: dc_poll_register 0x41: timeout
[ 24.107952] tegradc 15200000.display: dc timeout waiting for DC to stop
[ 24.159923] tegradc 15200000.display: dc_poll_register 0x41: timeout
[ 24.159931] tegradc 15200000.display: dc timeout waiting for DC to stop
[ 24.211951] tegradc 15200000.display: dc_poll_register 0x41: timeout
[ 24.211961] tegradc 15200000.display: timeout waiting for postcomp init state to promote
[ 24.263929] tegradc 15200000.display: dc_poll_register 0x41: timeout
[ 24.263940] tegradc 15200000.display: timeout waiting for win assignments to promote
[ 24.263944] tegradc 15200000.display: tegra_nvdisp_head_enable, failed head enable
[ 24.266911] tegradc 15210000.display: blank - powerdown
[ 343.242998] tegradc 15200000.display: blank - powerdown
[ 343.243018] tegradc 15210000.display: blank - powerdown
Thank you
