Display Problems from Nvidia Driver ... Quadro P600
I installed the latest NVIDIA driver version 340.108 for my card (Quadro P600) after which The DP-0 port into an HDMI port offsets the display so I can’t see the left side or bottom of the display but it is clear. The DVI port outputs makes the display blurry although the display is correctly proportioned. I don’t have a DP to DP cable today so I can’t tell if that works yet.
nvidia-installer log file '/var/log/nvidia-installer.log'
creation time: Thu Feb  6 11:51:04 2020
installer version: 340.108
PATH: /usr/lib64/qt-3.3/bin:/usr/local/sbin:/usr/local/bin:/sbin:/bin:/usr/sbin:/usr/bin:/root/bin
nvidia-installer command line:
    ./nvidia-installer
Unable to load: nvidia-installer ncurses v6 user interface
Using: nvidia-installer ncurses user interface
-> License accepted.
-> Installing NVIDIA driver version 340.108.
-> Would you like to register the kernel module sources with DKMS? This will allow DKMS to automatically build a new module, if you install a different kernel later. (Answer: Yes)
-> Installing both new and classic TLS OpenGL libraries.
-> Installing both new and classic TLS 32bit OpenGL libraries.
-> Install NVIDIA's 32-bit compatibility libraries? (Answer: Yes)
-> nvidia-installer will install the libvdpau and libvdpau_trace libraries that were included with this installer package. These libraries are available separately through the libvdpau project and will be removed from the NVIDIA Linux driver installer package in the future, so it is recommended that VDPAU users install libvdpau separately, e.g. by using packages available from their distributions, or by building from the sources available at:
http://people.freedesktop.org/~aplattner/vdpau
-> Searching for conflicting X files:
-> done.
-> Searching for conflicting OpenGL files:
-> done.
-> Installing 'NVIDIA Accelerated Graphics Driver for Linux-x86_64' (340.108):
   executing: '/sbin/ldconfig'...
   /sbin/ldconfig: file /usr/lib64/libImageProcessor.so is truncated
   /sbin/ldconfig: file /usr/lib64/libImageProcessor-x86_64.so is truncated
-> done.
-> Driver file installation is complete.
-> Installing DKMS kernel module:
-> done.
-> Running post-install sanity check:
-> done.
-> Post-install sanity check passed.
-> Shared memory test passed.
-> Running runtime sanity check:
-> done.
-> Runtime sanity check passed.
-> Would you like to run the nvidia-xconfig utility to automatically update your X configuration file so that the NVIDIA X driver will be used when you restart X?  Any pre-existing X configuration file will be backed up. (Answer: Yes)
-> Your X configuration file has been successfully updated.  Installation of the NVIDIA Accelerated Graphics Driver for Linux-x86_64 (version: 340.108) is now complete.
I would like to get the DP-HDMI working
Uninstalled 340 and installed 390 same issue.
Ended up being a bad video card … swapped in another and all is well.
