I’m trying to install the driver of the Nvidia Quadro P4000 in a workstation but for the moment i’m not able to make it works
First I tried to enable the Nvidia Driver form the GUI through System-Settings–> Software & Updates–>Additional Driver: it enable the drier 384.130 but it completely destroy the system that after that start in Rcovery mode.
I have reistalled the System and i wanted to try to install the proprietary driver downloaded by Nvidia: NVIDIA-Linux-x86_64-390.87.run
- Under /etc/modprobe.d i have added a blacklist-nouveau.cfg with the following two line blacklist nouveau and options nouveau modeset=0
- i have run this command sudo update-initramfs -u to regenerate initramfs
- The in the terminal i have stopped the lightdm service with sudo service lightdm stop
- The i tried to run ./NVIDIA-Linux-x86_64-390.87.run
But it pre-install script failed with the following erroer:
Unable to load: nvidia-installer ncurses v6 user interface
there is method to fix or i made some mistake? Below there is the complete log file
nvidia-installer log file '/var/log/nvidia-installer.log'
creation time: Mon Oct 8 17:11:49 2018
installer version: 390.87
PATH: /usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/snap/bin
nvidia-installer command line:
./nvidia-installer
Using: nvidia-installer ncurses user interface
-> Detected 8 CPUs online; setting concurrency level to 8.
-> Installing NVIDIA driver version 390.87.
-> Running distribution scripts
executing: '/usr/lib/nvidia/pre-install'...
-> done.
-> The distribution-provided pre-install script failed! Are you sure you want to continue? (Answer: Abort installation)
ERROR: Installation has failed. Please see the file '/var/log/nvidia-installer.log' for details. You may find suggestions on fixing installation problems in the README available on the Linux driver download page at www.nvidia.com.
