HI
I have NVIDIA® GeForce® 410M GPU. Tried to install drive NVIDIA-Linux-x86_64-390.87.run / NVIDIA-Linux-x86_64-390.129.run / NVIDIA-Linux-x86_64-430.40.run for ubuntu 18.04 64 bit.
It gives an error as below…
The distribution-provided pre-install script failed! Are you sure you want to continue?
Continue installation Abort installation
After continue…
ERROR: The Nouveau kernel driver is currently in use by your system. This driver is incompatible with the NVIDIA driver, and must be
disabled before proceeding. Please consult the NVIDIA driver README and your Linux distribution's documentation for details on how to
correctly disable the Nouveau kernel driver.
OK
After Ok…
WARNING: One or more modprobe configuration files to disable Nouveau are already present at:
/etc/modprobe.d/nvidia-installer-disable-nouveau.conf. Please be sure you have rebooted your system since these files were written.
If you have rebooted, then Nouveau may be enabled for other reasons, such as being included in the system initial ramdisk or in your
X configuration file. Please consult the NVIDIA driver README and your Linux distribution's documentation for details on how to
OK
After OK…
ERROR: Installation has failed. Please see the file '/var/log/nvidia-installer.log' for details. You may find suggestions on fixing
installation problems in the README available on the Linux driver download page at www.nvidia.com.
OK
Same goes for all 3 above mention version.
nvidia-installer.log (1.72 KB)
