I’m still having major issues getting DP to work.
I am now at the point where i have an fb being probed and mounted but i still don’t know if it is actually working (i’m still getting nothing out on a monitor).
I got this far by editing my dts and doing some hacks in /video/tegra/dc to force sor1 id 1
My dts has the following under host1x:
/* tegradc.1 */
dc@54240000 {
status = "okay";
nvidia,dc-flags = <TEGRA_DC_FLAG_ENABLED>;
nvidia,emc-clk-rate = <300000000>;
nvidia,cmu-enable = <1>;
nvidia,fb-bpp = <32>; /* bits per pixel */
nvidia,fb-flags = <TEGRA_FB_FLIP_ON_PROBE>;
/* dp */
vdd-dp-pwr-supply = <&vdd_3v3>;
avdd-dp-pll-supply = <&max77620_sd3>;
vdd-edp-sec-mode-supply = <&vdd_sys_boost>;
vdd-dp-pad-supply = <&max77620_ldo8>;
sor1 {
nvidia,sor1-output-type = "dp";
status = "okay";
compatible = "dp, display";
dp-display {
status = "okay";
nvidia,is_ext_dp_panel = <1>;
disp-default-out {
nvidia,out-type = <TEGRA_DC_OUT_DP>;
nvidia,out-align = <TEGRA_DC_ALIGN_MSB>;
nvidia,out-order = <TEGRA_DC_ORDER_RED_BLUE>;
nvidia,out-flags = <TEGRA_DC_OUT_CONTINUOUS_MODE>;
nvidia,out-pins = <TEGRA_DC_OUT_PIN_H_SYNC TEGRA_DC_OUT_PIN_POL_LOW
TEGRA_DC_OUT_PIN_V_SYNC TEGRA_DC_OUT_PIN_POL_LOW
TEGRA_DC_OUT_PIN_PIXEL_CLOCK TEGRA_DC_OUT_PIN_POL_LOW
TEGRA_DC_OUT_PIN_DATA_ENABLE TEGRA_DC_OUT_PIN_POL_HIGH>;
nvidia,out-parent-clk = "pll_d2";
i now have the following printing to dmesg:
tegradc tegradc.1: Display dc.54240000 registered with id=1
parse_dp_settings: No dp-gr-settings node
of_dc_parse_platform_data: could not find vrr-settings node
of_dc_parse_platform_data: could not find SD settings node
of_dc_parse_platform_data: could not find cmu node
of_dc_parse_platform_data: could not find cmu node for adobeRGB
tegradc tegradc.1: DT parsed successfully
tegradc tegradc.1: dp: couldn't get regulator vdd_hdmi_5v0
tegradc tegradc.1: nominal-pclk:25200000 parent:25200000 div:1.0 pclk:25200000 24948000~27468000
tegradc tegradc.1: dp: HPD is not detected
tegradc tegradc.1: dp: Failed to write DPCD data. CMD 0x600, Status 0x0
tegradc tegradc.1: dp: failed to power on panel (0xfffffff2)
tegradc tegradc.1: probed
tegradc tegradc.1: fb registered
I now get the following when running startx:
[ 1433.582]
X.Org X Server 1.15.1
Release Date: 2014-04-13
[ 1433.582] X Protocol Version 11, Revision 0
[ 1433.582] Build Operating System: Linux 3.2.0-60-highbank armv7l Ubuntu
[ 1433.582] Current Operating System: Linux localhost 3.10.67 #39 SMP PREEMPT Thu Jul 21 17:23:36 EDT 2016 aarch64
[ 1433.582] Kernel command line: fbcon=map:0 console=tty0 console=ttyS0,115200n8 androidboot.modem=none androidboot.serialno=P2180A00P00940c003fd androidboot.security=non-secure tegraid=21.1.2.0.0 ddr_die=2048M@2048M ddr_die=2048M@4096t
[ 1433.583] Build Date: 30 July 2014 12:24:34AM
[ 1433.583] xorg-server 2:1.15.1-0ubuntu2.1 (For technical support please see http://www.ubuntu.com/support)
[ 1433.583] Current version of pixman: 0.30.2
[ 1433.583] Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
[ 1433.583] Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[ 1433.583] (==) Log file: "/var/log/Xorg.0.log", Time: Thu Jul 21 21:50:06 2016
[ 1433.583] (==) Using config file: "/etc/X11/xorg.conf"
[ 1433.584] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 1433.584] (==) No Layout section. Using the first Screen section.
[ 1433.584] (==) No screen section available. Using defaults.
[ 1433.584] (**) |-->Screen "Default Screen Section" (0)
[ 1433.585] (**) | |-->Monitor "<default monitor>"
[ 1433.585] (==) No device specified for screen "Default Screen Section".
Using the first device section listed.
[ 1433.585] (**) | |-->Device "Tegra0"
[ 1433.585] (==) No monitor specified for screen "Default Screen Section".
Using a default monitor configuration.
[ 1433.585] (==) Automatically adding devices
[ 1433.585] (==) Automatically enabling devices
[ 1433.585] (==) Automatically adding GPU devices
[ 1433.585] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
[ 1433.585] Entry deleted from font path.
[ 1433.585] (WW) The directory "/usr/share/fonts/X11/100dpi/" does not exist.
[ 1433.585] (WW) The directory "/usr/share/fonts/X11/75dpi/" does not exist.
[ 1433.585] (WW) The directory "/usr/share/fonts/X11/100dpi" does not exist.
[ 1433.586] (WW) The directory "/usr/share/fonts/X11/75dpi" does not exist.
[ 1433.586] Entry deleted from font path.
[ 1433.586] (==) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/Type1,
built-ins
[ 1433.586] (==) ModulePath set to "/usr/lib/arm-linux-gnueabihf/xorg/extra-modules,/usr/lib/xorg/extra-modules,/usr/lib/xorg/modules"
[ 1433.586] (II) The server relies on udev to provide the list of input devices.
If no devices become available, reconfigure udev or disable AutoAddDevices.
[ 1433.586] (II) Loader magic: 0xab190f10
[ 1433.586] (II) Module ABI versions:
[ 1433.586] X.Org ANSI C Emulation: 0.4
[ 1433.586] X.Org Video Driver: 15.0
[ 1433.586] X.Org XInput driver : 20.0
[ 1433.586] X.Org Server Extension : 8.0
[ 1433.586] Initializing built-in extension Generic Event Extension
[ 1433.586] Initializing built-in extension SHAPE
[ 1433.586] Initializing built-in extension MIT-SHM
[ 1433.586] Initializing built-in extension XInputExtension
[ 1433.586] Initializing built-in extension XTEST
[ 1433.586] Initializing built-in extension BIG-REQUESTS
[ 1433.586] Initializing built-in extension SYNC
[ 1433.586] Initializing built-in extension XKEYBOARD
[ 1433.587] Initializing built-in extension XC-MISC
[ 1433.587] Initializing built-in extension SECURITY
[ 1433.587] Initializing built-in extension XINERAMA
[ 1433.587] Initializing built-in extension XFIXES
[ 1433.587] Initializing built-in extension RENDER
[ 1433.587] Initializing built-in extension RANDR
[ 1433.587] Initializing built-in extension COMPOSITE
[ 1433.587] Initializing built-in extension DAMAGE
[ 1433.587] Initializing built-in extension MIT-SCREEN-SAVER
[ 1433.587] Initializing built-in extension DOUBLE-BUFFER
[ 1433.587] Initializing built-in extension RECORD
[ 1433.587] Initializing built-in extension DPMS
[ 1433.587] Initializing built-in extension Present
[ 1433.587] Initializing built-in extension DRI3
[ 1433.587] Initializing built-in extension X-Resource
[ 1433.587] Initializing built-in extension XVideo
[ 1433.587] Initializing built-in extension XVideo-MotionCompensation
[ 1433.587] Initializing built-in extension SELinux
[ 1433.587] Initializing built-in extension XFree86-VidModeExtension
[ 1433.587] Initializing built-in extension XFree86-DGA
[ 1433.587] Initializing built-in extension XFree86-DRI
[ 1433.587] Initializing built-in extension DRI2
[ 1433.587] (WW) "dri" will not be loaded unless you've specified it to be loaded elsewhere.
[ 1433.587] (II) "glx" will be loaded by default.
[ 1433.587] (WW) "xmir" is not to be loaded by default. Skipping.
[ 1433.587] (II) LoadModule: "extmod"
[ 1433.588] (II) Module "extmod" already built-in
[ 1433.588] (II) LoadModule: "glx"
[ 1433.588] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 1433.612] (II) Module glx: vendor="NVIDIA Corporation"
[ 1433.612] compiled for 4.0.2, module version = 1.0.0
[ 1433.612] Module class: X.Org Server Extension
[ 1433.612] (II) NVIDIA GLX Module 23.2.0 Release Build (integ_stage_rel) (buildbrain@mobile-u64-630) Mon Feb 8 17:42:14 PST 2016
[ 1433.612] Loading extension GLX
[ 1433.612] (II) LoadModule: "nvidia"
[ 1433.612] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[ 1433.613] (II) Module nvidia: vendor="NVIDIA Corporation"
[ 1433.613] compiled for 4.0.2, module version = 1.0.0
[ 1433.613] Module class: X.Org Video Driver
[ 1433.613] (II) NVIDIA dlloader X Driver 23.2.0 Release Build (integ_stage_rel) (buildbrain@mobile-u64-630) Mon Feb 8 17:44:11 PST 2016
[ 1433.613] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[ 1433.613] (--) using VT number 7
[ 1433.613] (WW) Falling back to old probe method for NVIDIA
[ 1433.613] (II) Loading sub module "fb"
[ 1433.613] (II) LoadModule: "fb"
[ 1433.614] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 1433.614] (II) Module fb: vendor="X.Org Foundation"
[ 1433.614] compiled for 1.15.1, module version = 1.0.0
[ 1433.614] ABI class: X.Org ANSI C Emulation, version 0.4
[ 1433.614] (II) Loading sub module "wfb"
[ 1433.614] (II) LoadModule: "wfb"
[ 1433.614] (II) Loading /usr/lib/xorg/modules/libwfb.so
[ 1433.615] (II) Module wfb: vendor="X.Org Foundation"
[ 1433.615] compiled for 1.15.1, module version = 1.0.0
[ 1433.615] ABI class: X.Org ANSI C Emulation, version 0.4
[ 1433.615] (II) Loading sub module "ramdac"
[ 1433.615] (II) LoadModule: "ramdac"
[ 1433.615] (II) Module "ramdac" already built-in
[ 1433.615] (II) NVIDIA(0): Creating default Display subsection in Screen section
"Default Screen Section" for depth/fbbpp 24/32
[ 1433.615] (==) NVIDIA(0): Depth 24, (==) framebuffer bpp 32
[ 1433.615] (==) NVIDIA(0): RGB weight 888
[ 1433.615] (==) NVIDIA(0): Default visual is TrueColor
[ 1433.615] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[ 1433.615] (**) NVIDIA(0): Option "AllowEmptyInitialConfiguration" "true"
[ 1433.616] (**) NVIDIA(0): Enabling 2D acceleration
[ 1433.632] (EE) NVIDIA(GPU-0): Failed to initialize client
[ 1433.632] (EE)
[ 1433.632] (EE) Backtrace:
[ 1433.632] (EE)
[ 1433.632] (EE) Segmentation fault at address 0x48
[ 1433.632] (EE)
Fatal server error:
[ 1433.632] (EE) Caught signal 11 (Segmentation fault). Server aborting
[ 1433.632] (EE)
[ 1433.633] (EE)
Please consult the The X.Org Foundation support
at http://wiki.x.org
for help.
[ 1433.633] (EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
[ 1433.633] (EE)
[ 1433.633] (EE) Server terminated with error (1). Closing log file.
