Displays that work with Jetson Orin Nano
I’ve been exploring display options for the NVIDIA Jetson Orin Nano but noticed that some models specify compatibility only with the previous-generation Jetson Nano, not the Orin Nano. Since the Orin Nano uses a DisplayPort (DP) connection and the screen I’m considering uses HDMI, could I use an active DP-to-HDMI cable or adapter to bridge this connection? Would this effectively circumvent the issue, or are there other compatibility factors I should be aware of, such as driver support or hardware limitations?
For example:
https://www.amazon.com/dp/B07FDYXPT7?ref=cm_sw_r_cp_ud_dp_QY73HXJ4ER14D0FFDM4J&ref_=cm_sw_r_cp_ud_dp_QY73HXJ4ER14D0FFDM4J&social_share=cm_sw_r_cp_ud_dp_QY73HXJ4ER14D0FFDM4J
Sorry for the late response.
Hi kayccc,
This is not an issue anymore, it worked using the active adapter with the touchscreen I am using.
