Can the Orin Nano able to support this resolution specification?
I connected to this device, it does not work on the display.
- Refresh Frequency: 60Hz
- Screen Resolution: 1920 x 1080
Thank you.
Regards,
CC
Thank you.
Regards,
CC
There is a DP port on Orin Nano developer kit. The device looks to be with HDMI out. Do you use DP to HDMI adapter?
yes, a DP to HDMI adapter is used. The adapter is tested and works fine.
The issue may be with the adapter. You may try other adapters, or use Orin Nano module + Xavier NX carrier board. It is HDMI port on Xavier NX carrier board so adapter is not required.
Thanks for your reply.
Do you have any ideas or methods to configure the resolution?
Thank you.
Please refer to the topic and try:
How do I change the monitor resolution to 1920x1080 in Jetson Nano console mode?
