HDMI not working
Hardware:
Orin nano module P3767-0003 + customboard.
Custom borad status:
Modified form Orin nano dev kit, but changed DP to HDMI.
Jetpack:
5.1.3
Problems:
Tested two monitors, HP and Waveshare. On the HP monitor everything works fine. But on the Waveshare monitor there is no output. I also tested another monitor and it also didn’t work properly.
Waveshare monitor works fine on other devices.
When unplugging and plugging the monitor, the Xorg.0.log is as follows:
Xorg.0.log.txt (3.1 KB)
The EDID of both displays can be read normally:
xrandr --props -display :0.0 | edid-decode
edid_hp.txt (4.8 KB)
edid_waveshare.txt (4.5 KB)
I don’t see any specific error from your xorg log.
Will it work if you switch to 1920x1080 on waveshare by using xrandr command?
Do you mean this?
xrandr --fb 1920x1080 -display :0.0
Still can’t output normally.
How to determine whether Orin nano is in DP++ mode or HDMI mode?
first, give us your xrandr result.
I changed the resolution according to here, but it still doesn’t display properly.
xrandr result for waveshare monitor:
$ xrandr
Screen 0: minimum 8 x 8, current 1920 x 1080, maximum 32767 x 32767
HDMI-0 connected primary 1920x1080+0+0 (normal left inverted right x axis y axis) 518mm x 324mm
   1280x800      59.49 +
   1920x1080     60.00*   59.72    50.00    23.98
   1280x720      60.00    59.94    50.00
   720x576       50.00
   720x480       59.94
   640x480       59.93
If you saw “HDMI-0” in xrandr then it is not in DP++ mode anymore.
So even using “xrandr --output HDMI-0 --mode 1920x1080” won’t give you the GUI?
Sadly yes.
