I have a 1440p DP display connected through HDMI-to-DP adapter. With Jetson Xavier NX, everything works fine.
With Jetson Orin NX, the HDMI port cannot output more than 720P
When I added the DebugMode option to X11.conf this was in the logs:
[ 32.589] (WW) NVIDIA(GPU-0): Validating Mode "2560x1440_60":
[ 32.589] (WW) NVIDIA(GPU-0): Mode Source: EDID
[ 32.589] (WW) NVIDIA(GPU-0): 2560 x 1440 @ 60 Hz
[ 32.589] (WW) NVIDIA(GPU-0): Pixel Clock : 241.50 MHz
[ 32.589] (WW) NVIDIA(GPU-0): HRes, HSyncStart : 2560, 2608
[ 32.589] (WW) NVIDIA(GPU-0): HSyncEnd, HTotal : 2640, 2720
[ 32.589] (WW) NVIDIA(GPU-0): VRes, VSyncStart : 1440, 1443
[ 32.589] (WW) NVIDIA(GPU-0): VSyncEnd, VTotal : 1448, 1481
[ 32.589] (WW) NVIDIA(GPU-0): Sync Polarity : +H -V
[ 32.589] (WW) NVIDIA(GPU-0): Mode is rejected: PixelClock (241.5 MHz) too high for
[ 32.589] (WW) NVIDIA(GPU-0): Display Device (Max: 165.0 MHz).
[ 32.589] (WW) NVIDIA(GPU-0): GPU extended capability check failed.
[ 32.589] (WW) NVIDIA(GPU-0): Mode "2560x1440_60" is invalid.
This behaviour was the same on our custom carrier board and on seeed A203V2 carrier board so I don’t think it’s a faulty board on our side.
Do you have any insight into why is this happenning?
