Can the Orin Nano DP output a resolution of 800*1280?
The provided context does not explicitly mention the maximum resolution supported by the Jetson Orin Nano’s DP (DisplayPort) output. However, we can make an educated guess based on the available information.
The context mentions the Jetson Orin Nano’s HDMI interface and its related discussions, but it does not provide specific details about the DP output resolution. However, we can look at the general specifications of the Jetson Orin Nano and its supported display interfaces.
The Jetson Orin Nano is a powerful AI computing module that supports various display interfaces, including HDMI, DisplayPort, and eDP (Embedded DisplayPort). While the context does not provide explicit information about the DP output resolution, we can assume that the Jetson Orin Nano’s DP output is capable of supporting high-resolution displays.
Typically, DisplayPort 1.4, which is a common version supported by many modern devices, can support resolutions up to 5120 x 2880 at 60 Hz or 3840 x 2160 at 120 Hz. However, without explicit information about the Jetson Orin Nano’s DP output capabilities, we cannot confirm whether it can support a resolution of 800 x 1280.
To answer your question, it is possible that the Jetson Orin Nano’s DP output can support a resolution of 800 x 1280, but we would need more specific information about its display output capabilities to confirm this.
In comparison, the context does provide information about the HDMI interface on the Jetson Orin Nano, including discussions about signal amplitude, signal strength, and TMDS line pull-down resistors. However, this information is specific to the HDMI interface and does not provide direct insights into the DP output resolution.
In summary, while we cannot confirm the exact resolution supported by the Jetson Orin Nano’s DP output, it is possible that it can support a resolution of 800 x 1280 based on general DisplayPort specifications. However, more specific information about the Jetson Orin Nano’s display output capabilities is needed to provide a definitive answer.
We use DP to DSI Conversion, so BSP seting 800 *1280 or 1280 * 800?
we don’t guarantee that DP to DSI conversion would work fine as not validated that.
The mode should be decided by the EDID read from the device itself.
