Jetson ORIN NANO DisplayPort or HDMI Port possible?
HELLO
  1. Does the Jetson Orin Nano support HDMI output?
  2. “The Jetson Orin Nano Developer Kit is configured with one DisplayPort and one HDMI port. Is video output supported on both ports?”
The Jetson Orin Nano module supports HDMI in addition to DisplayPort (DP). According to the provided documentation, the Jetson Orin Nano Developer Kit carrier board design files are provided as a reference design, and both Jetson Orin Nano and Jetson Orin NX modules are compatible with this carrier board.
The Jetson Orin Nano module itself has one DisplayPort (DP) interface, but it does not have a built-in HDMI port. However, you can either customize the carrier baseboard to HDMI or plug the Jetson Orin Nano module to the Xavier NX carrier board that comes with an HDMI port.
To enable HDMI output on the Jetson Orin Nano, you need to use the p3509-a02-p3767-0000.conf config file to flash the board. The provided example command shows how to flash the device with HDMI support.
In terms of video output support, the Jetson Orin Nano module supports video output on the DisplayPort (DP) interface. If you customize the carrier baseboard to HDMI or use the Xavier NX carrier board with an HDMI port, you can also get video output on the HDMI port.
In comparison, the Jetson Orin NX module has one DisplayPort (DP) interface and can be used with the Xavier NX carrier board that comes with an HDMI port, similar to the Jetson Orin Nano module. However, the Jetson Orin NX module does not have a built-in HDMI port.
In summary, the Jetson Orin Nano module supports HDMI output, but it requires customization of the carrier baseboard or the use of the Xavier NX carrier board with an HDMI port. Video output is supported on both the DisplayPort (DP) interface and the HDMI port (if available).
  1. If you are making your own custom board with HDMI port, then it would work with proper software configuration.
  2. Not sure what you are talking about here because Orin Nano devkit only has one DP port. There is no HDMI on it.
