Jetson orin nx 16GB module with 2 nos of DP++ outputs
Team,
I’m using Jetson orin NX 16GB module. My requirement is two DVI outputs from Jetson orin module. Kindly check the feasibility.
Based on the provided context, I couldn’t find any information about DVI outputs on the Jetson Orin NX modules. The context primarily focuses on the technical specifications, thermal design, and product design guides for the Jetson Orin NX and Nano series modules.
However, I can suggest some possible alternatives or workarounds for achieving two DVI outputs from the Jetson Orin NX 16GB module:
  1. Check the module’s connector and pinout: Referring to the Jetson Orin NX Series and Jetson Orin Nano Series Product Design Guide (DG-10931-001_v1.4), Chapter 10, MIPI CSI Video Input, it seems that the module has MIPI CSI lanes, but there is no mention of DVI outputs. You may want to verify the module’s connector and pinout to see if there are any unused or configurable pins that could be used for DVI output.
  2. Use an external adapter or converter: You might consider using an external adapter or converter to convert the module’s output (e.g., HDMI, DisplayPort, or MIPI CSI) to DVI. This would require additional hardware and may introduce latency or compatibility issues.
  3. Explore software-based solutions: Depending on your specific use case, you might be able to use software-based solutions, such as virtual displays or screen sharing, to achieve two DVI outputs. This would likely require significant development and testing efforts.
  4. Contact NVIDIA support or forums: If you’re unable to find any information or solutions, I recommend reaching out to NVIDIA support or forums to inquire about the feasibility of two DVI outputs on the Jetson Orin NX 16GB module. They may be able to provide more detailed information or suggest alternative solutions.
In summary, based on the provided context, it’s unclear whether the Jetson Orin NX 16GB module supports two DVI outputs. You may need to explore alternative solutions, such as using external adapters or converters, software-based solutions, or contacting NVIDIA support for further guidance.
HDMI or DP are natively supported. Please refer to the Jetson Orin NX Series and Orin Nano Series Design Guide https://developer.nvidia.com/downloads/jetson-orin-nx-series-nano-series-design-guide You could use suitable adapters, if needed.
