Dp/HDMI Output on Jetson Orin NX module
Hi Team,
We are planning to develop a custom board with Orin NX SoM. The few queries which we wanted to get clarified are
  1. We need two video outputs to the external world. This can be either 2 HDMI or 1HDMI and 1DP. Does Orin NX supports two video output simultaneously? If yes, this can be mirror output on both port or independent video output? If not any suggestion to get two video outputs?
  2. Does Orin NX supports parallel video inputs instead of MIPI-CSI?
Anand B
Only DP could have 2 video output by using MST. 2 HDMI is not possible.
hello anandb1,
may I know what’s the interface you’re going to receive the video?
It is CCIR 601/656 interface
Can you please share any reference documents and design documents if any to get to know more and design 2 DP output?
that’s not supported by Orin NX.
May i know what type of parallel video interface Orin NX supports?
CSI-2 (Camera Serial Interface).
Thank you for the details.
Also, Can you please share any reference documents and design documents if any to get to know more for designing 2-DP video output?
