DJI PSDK USB Bulk configuration
I’m following this guide to use the Jetson Orin Nano (JP6) as a companion computer for the DJI PSDK(DJI M300). My connections are as described in the guide. but I’m having a hard time with the usb bulk configuration.
According to the guide. I have to download a startup bulk folder that contains the configuration files for the usb-device.
I changed the file so that the paths of bulk1 and bulk2 are:
/home/bon/Desktop/startup_bulk/startup_bulk /dev/usb-ffs/bulk1
/home/bon/Desktop/startup_bulk/startup_bulk /dev/usb-ffs/bulk2
(bon is my user)
sudo cp startup_bulk/psdk-usb-configure.sh  /opt/nvidia/l4t-usb-device-mode-start.sh
#!/bin/bash
# Copyright (c) 2017-2020, NVIDIA CORPORATION.  All rights reserved.
# Redistribution and use in source and binary forms, with or without
# modification, are permitted provided that the following conditions
# are met:
#  * Redistributions of source code must retain the above copyright
#    notice, this list of conditions and the following disclaimer.
#  * Redistributions in binary form must reproduce the above copyright
#    notice, this list of conditions and the following disclaimer in the
#    documentation and/or other materials provided with the distribution.
#  * Neither the name of NVIDIA CORPORATION nor the names of its
#    contributors may be used to endorse or promote products derived
#    from this software without specific prior written permission.
# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS ``AS IS'' AND ANY
# EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
# IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
# PURPOSE ARE DISCLAIMED.  IN NO EVENT SHALL THE COPYRIGHT OWNER OR
# CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
# EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
# PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR
# PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY
# OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
# (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
# OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
set -e
script_dir="$(cd "$(dirname "$0")" && pwd)"
. "${script_dir}/nv-l4t-usb-device-mode-config.sh"
# Wait for any modules to load and initialize
for attempt in $(seq 60); do
    udc_dev_t210=700d0000.xudc
    if [ -e "/sys/class/udc/${udc_dev_t210}" ]; then
        udc_dev="${udc_dev_t210}"
        break
    fi
    udc_dev_t186=3550000.xudc
    if [ -e "/sys/class/udc/${udc_dev_t186}" ]; then
        udc_dev="${udc_dev_t186}"
        break
    fi
    sleep 1
done
if [ "${udc_dev}" == "" ]; then
    echo No known UDC device found
    exit 1
fi
macs_file="${script_dir}/mac-addresses"
if [ -f "${macs_file}" ]; then
    . "${macs_file}"
else
    # Generate unique data
    if [ -f /proc/device-tree/serial-number ]; then
        random="$(md5sum /proc/device-tree/serial-number|cut -c1-12)"
    else
        random="$(echo "no-serial"|md5sum|cut -c1-12)"
    fi
    # Extract 6 bytes
    b1="$(echo "${random}"|cut -c1-2)"
    b2="$(echo "${random}"|cut -c3-4)"
    b3="$(echo "${random}"|cut -c5-6)"
    b4="$(echo "${random}"|cut -c7-8)"
    b5="$(echo "${random}"|cut -c9-10)"
    b6="$(echo "${random}"|cut -c11-12)"
    # Clear broadcast/multicast, set locally administered bits
    b1="$(printf "%02x" "$(("0x${b1}" & 0xfe | 0x02))")"
    # Set 4 LSBs to unique value per interface
    b6_rndis_h="$(printf "%02x" "$(("0x${b6}" & 0xfc | 0x00))")"
    b6_rndis_d="$(printf "%02x" "$(("0x${b6}" & 0xfc | 0x01))")"
    b6_ecm_h="$(printf "%02x" "$(("0x${b6}" & 0xfc | 0x02))")"
    b6_ecm_d="$(printf "%02x" "$(("0x${b6}" & 0xfc | 0x03))")"
    # Construct complete MAC per interface
    mac_rndis_h="${b1}:${b2}:${b3}:${b4}:${b5}:${b6_rndis_h}"
    mac_rndis_d="${b1}:${b2}:${b3}:${b4}:${b5}:${b6_rndis_d}"
    mac_ecm_h="${b1}:${b2}:${b3}:${b4}:${b5}:${b6_ecm_h}"
    mac_ecm_d="${b1}:${b2}:${b3}:${b4}:${b5}:${b6_ecm_d}"
    # Save values for next boot
    echo "mac_rndis_h=${mac_rndis_h}" > "${macs_file}"
    echo "mac_rndis_d=${mac_rndis_d}" >> "${macs_file}"
    echo "mac_ecm_h=${mac_ecm_h}" >> "${macs_file}"
    echo "mac_ecm_d=${mac_ecm_d}" >> "${macs_file}"
fi
mkdir -p /sys/kernel/config/usb_gadget/l4t
cd /sys/kernel/config/usb_gadget/l4t
# If this script is modified outside NVIDIA, the idVendor and idProduct values
# MUST be replaced with appropriate vendor-specific values.
echo 0x0955 > idVendor
echo 0x7020 > idProduct
# BCD value. Each nibble should be 0..9. 0x1234 represents version 12.3.4.
echo 0x0002 > bcdDevice
# Informs Windows that this device is a composite device, i.e. it implements
# multiple separate protocols/devices.
echo 0xEF > bDeviceClass
echo 0x02 > bDeviceSubClass
echo 0x01 > bDeviceProtocol
mkdir -p strings/0x409
    serialnumber="$(cat /proc/device-tree/serial-number|tr -d '\000')"
else
    serialnumber=no-serial
fi
echo "${serialnumber}" > strings/0x409/serialnumber
# If this script is modified outside NVIDIA, the manufacturer and product values
echo "NVIDIA" > strings/0x409/manufacturer
echo "Linux for Tegra" > strings/0x409/product
cfg=configs/c.1
mkdir -p "${cfg}"
cfg_str=""
# Note: RNDIS must be the first function in the configuration, or Windows'
# RNDIS support will not operate correctly.
if [ ${enable_rndis} -eq 1 ]; then
    cfg_str="${cfg_str}+RNDIS"
    func=functions/rndis.usb0
    mkdir -p "${func}"
    echo "${mac_rndis_h}" > "${func}/host_addr"
    echo "${mac_rndis_d}" > "${func}/dev_addr"
    ln -sf "${func}" "${cfg}"
    # Informs Windows that this device is compatible with the built-in RNDIS
    # driver. This allows automatic driver installation without any need for
    # a .inf file or manual driver selection.
    echo 1 > os_desc/use
    echo 0xcd > os_desc/b_vendor_code
    echo MSFT100 > os_desc/qw_sign
    echo RNDIS > "${func}/os_desc/interface.rndis/compatible_id"
    echo 5162001 > "${func}/os_desc/interface.rndis/sub_compatible_id"
    ln -sf "${cfg}" os_desc
fi
# If two USB configs are created, and the second contains RNDIS and ACM, then
# Windows will ignore at the ACM function in that config. Consequently, this
# script creates only a single USB config.
if [ ${enable_acm} -eq 1 ]; then
    cfg_str="${cfg_str}+ACM"
    func=functions/acm.GS0
    mkdir -p "${func}"
fi
# Copy system version information into the exposed filesystem image,
# so that any system that's attached to the USB port can identify this device.
# Do this even if $enable_ums!=1, since $fs_img is locally mounted too.
mntpoint="/mnt/l4t-devmode-$$"
rm -rf "${mntpoint}"
mkdir -p "${mntpoint}"
mount -o loop "${fs_img}" "${mntpoint}"
rm -rf "${mntpoint}/version"
mkdir -p "${mntpoint}/version"
if [ -f /etc/nv_tegra_release ]; then
    cp /etc/nv_tegra_release "${mntpoint}/version"
fi
if dpkg -s nvidia-l4t-core > /dev/null 2>&1; then
    dpkg -s nvidia-l4t-core > "${mntpoint}/version/nvidia-l4t-core.dpkg-s.txt"
fi
cp -r /proc/device-tree/chosen/plugin-manager "${mntpoint}/version/plugin-manager"
umount "${mntpoint}"
if [ ${enable_ums} -eq 1 ]; then
    cfg_str="${cfg_str}+UMS"
    func=functions/mass_storage.0
    mkdir -p "${func}"
    # Prevent users from corrupting the disk image; make it read-only
    echo 1 > "${func}/lun.0/ro"
    echo "${fs_img}" > "${func}/lun.0/file"
fi
if [ ${enable_ecm} -eq 1 ]; then
    cfg_str="${cfg_str}+${ecm_ncm_name}"
    func=functions/${ecm_ncm}.usb0
    mkdir -p "${func}"
    echo "${mac_ecm_h}" > "${func}/host_addr"
    echo "${mac_ecm_d}" > "${func}/dev_addr"
fi
enable_bulk=1
if [ ${enable_bulk} -eq 1 ]; then
    mkdir -p /dev/usb-ffs
    cfg_str="${cfg_str}+BULK1"
    mkdir -p /dev/usb-ffs/bulk1
    func=functions/ffs.bulk1
    mkdir -p "${func}"
    mount -o mode=0777 -o uid=2000 -o gid=2000 -t functionfs bulk1 /dev/usb-ffs/bulk1
    /home/bon/Desktop/startup_bulk/startup_bulk /dev/usb-ffs/bulk1 &
    sleep 3
    cfg_str="${cfg_str}+BULK2"
    mkdir -p /dev/usb-ffs/bulk2
    func=functions/ffs.bulk2
    mkdir -p "${func}"
    mount -o mode=0777 -o uid=2000 -o gid=2000 -t functionfs bulk2 /dev/usb-ffs/bulk2
    /home/bon/Desktop/startup_bulk/startup_bulk /dev/usb-ffs/bulk2 &
    sleep 3
fi
mkdir -p "${cfg}/strings/0x409"
# :1 in the variable expansion strips the first character from the value. This
# removes the unwanted leading + sign. This simplifies the logic to construct
# $cfg_str above; it can always add a leading delimiter rather than only doing
# so unless the string is previously empty.
echo "${cfg_str:1}" > "${cfg}/strings/0x409/configuration"
# Create and configure the network bridge before setting the UDC device. This
# ensures that no matter how quickly udev events (which run -runtime-start.sh)
# are triggered after setting the UDC device below, the bridge device is
# guaranteed to exist, so -runtime-start.sh is guaranteed to be able to
# configure it.
# Set the device to "down" initially; if/when -runtime-start.sh runs in response
# to cable presence, the interface will be set to "up".
/sbin/brctl addbr l4tbr0
/sbin/ifconfig l4tbr0 down
echo "${udc_dev}" > UDC
# Ethernet devices require additional configuration. This must happen after the
# UDC device is assigned, since that triggers the creation of the Tegra-side
# Ethernet interfaces.
# This script always assigns any-and-all Ethernet devices to an Ethernet
# bridge, and assigns the static IP to that bridge. This allows the script to
# more easily handle the potentially variable set of Ethernet devices.
# If your custom use-case requires separate IP addresses per interface, or
# only ever has one interface active, you may modify this script to skip
# bridge creation, and assign IP address(es) directly to the interface(s).
    /sbin/brctl addif l4tbr0 "$(cat functions/rndis.usb0/ifname)"
    /sbin/ifconfig "$(cat functions/rndis.usb0/ifname)" up
fi
    /sbin/brctl addif l4tbr0 "$(cat functions/${ecm_ncm}.usb0/ifname)"
    /sbin/ifconfig "$(cat functions/${ecm_ncm}.usb0/ifname)" up
fi
cd - # Out of /sys/kernel/config/usb_gadget
# Create a local disk device that exposes the same filesystem image that's
# exported over USB. This will allow local users to see the files too.
/sbin/losetup -f -r "${fs_img}"
exit 0
but after the restart when i run this
ps -aux | grep startup_bulk
i get
bon         7574  0.0  0.0  11156  2152 pts/0    S+   10:34   0:00 grep --color=auto startup_bulk
I understand that I should see both paths /dev/usb-ffs/bulk1 and /dev/usb-ffs/bulk2 but that is not the case.
Reading the file i see that is trying to use either 700d0000.xudc or 3550000.xudc but none of those are in /sys/class/udc/ (where the script tries to find it) I only have 3550000.usb
my question is. should i have 700d0000.xudc or 3550000.xudc in /sys/class/udc/ or am i missing something else?
this is the status of the usb-device-mode
this is the tegra release information:
head -n 1 /etc/nv_tegra_release
R36 (release), REVISION: 3.0, GCID: 36191598, BOARD: generic, EABI: aarch64, DATE: Mon May 6 17:34:21 UTC 2024
ok im a bit confused now. I removed the configuration. avoided the usb otg adapter. connected the eport to the usbA of the jetson. run the example with sudo and it works. maybe not that fast but it works. Ill try to update on that later
Looks like the platform is Jetson Nano instead of Jetson Orin Nano. Not sure if the same steps can be applied to Orin Nano. We would suggest check with the vendor for further help.
Hello! Did you connect the UART TX RX pins of the Eport to USB-A of the jetson using some FTDI or did you use a USB-C to USB-A cable to connect the USB output of the Eport to a USB-A port of the jetson. I was able to connect the UART outputs to the jetson and now simple features like widget, flight control, etc work. but I need to be able to subscribe the images from the drone using the USB-C output. I am using Matrice M3TD drone with a jetson Orin nano but the DJI_USE_UART_AND_USB_BULK_DEVICE setting doesn’t work. Only DJI_USE_ONLY_UART works so far.
