We have a custom carrier board with Orin - JP 5.1.2
I want to use the usb0 port as a host device
We have a FTDI chip connected to usb0 on the hardware and we are unable to detect it
i encounter the following errors:
[ 30.230494] usb0: HOST MAC be:69:b9:83:6d:2a
[ 30.230502] usb0: MAC be:69:b9:83:6d:2b
[ 30.242297] l4tbr0: port 2(usb0) entered blocking state
[ 30.242309] l4tbr0: port 2(usb0) entered disabled state
[ 30.242418] device usb0 entered promiscuous mode
Does usb 1-1 in the dmesg mean USB0? it says device not responding, we have two FTDI chips connected - one on USB0 and the other on USB1
**[ 7.684444] usb 1-1: new low-speed USB device number 2 using tegra-xusb**
**[ 7.820739] usb 1-1: device descriptor read/64, error -71**
**[ 8.064743] usb 1-1: device descriptor read/64, error -71**
**[ 8.304442] usb 1-1: new low-speed USB device number 3 using tegra-xusb**
**[ 8.440921] usb 1-1: device descriptor read/64, error -71**
**[ 8.680621] usb 1-1: device descriptor read/64, error -71**
**[ 8.796420] usb usb1-port1: attempt power cycle**
**[ 9.208444] usb 1-1: new low-speed USB device number 4 using tegra-xusb**
**[ 9.216624] usb 1-1: Device not responding to setup address.**
**[ 9.429848] usb 1-1: Device not responding to setup address.**
**[ 9.644440] usb 1-1: device not accepting address 4, error -71**
**[ 9.776442] usb 1-1: new low-speed USB device number 5 using tegra-xusb**
**[ 9.784429] usb 1-1: Device not responding to setup address.**
**[ 9.997845] usb 1-1: Device not responding to setup address.**
**[ 10.228441] usb 1-1: device not accepting address 5, error -71**
[ 10.234723] usb usb1-port1: unable to enumerate USB device
[ 10.368516] usb 1-2: new high-speed USB device number 6 using tegra-xusb
[ 10.528943] usb 1-2: New USB device found, idVendor=0403, idProduct=6011, bcdDevice= 8.00
[ 10.537358] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 10.544698] usb 1-2: Product: Quad RS232-HS
[ 10.548983] usb 1-2: Manufacturer: FTDI
[ 10.752442] usb 1-3: new high-speed USB device number 7 using tegra-xusb
[ 10.912625] usb 1-3: New USB device found, idVendor=0781, idProduct=55ab, bcdDevice= 1.00
[ 10.921050] usb 1-3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 10.928392] usb 1-3: Product: SanDisk 3.2Gen1
[ 10.932947] usb 1-3: Manufacturer: USB
[ 10.936891] usb 1-3: SerialNumber: 0401560f40952dbc0e3436df992295ab6675723839beef3157b08d7291ecd0dd91ef00000000000000000000fee19030008c2a18ab558107562ee5c1
[ 10.952338] usb-storage 1-3:1.0: USB Mass Storage device detected
[ 10.959457] scsi host0: usb-storage 1-3:1.0
[ 18.023867] fusb301 1-0025: failed to read device id, err : 0xffffff87
[ 18.031260] fusb301 1-0025: fusb301 not support
[ 18.036135] fusb301: probe of 1-0025 failed with error -22
[ 19.009444] usbcore: registered new interface driver ftdi_sio
[ 19.015393] usbserial: USB Serial support registered for FTDI USB Serial Device
[ 19.029834] usb 1-2: Detected FT4232H
[ 19.034747] usb 1-2: FTDI USB Serial Device converter now attached to ttyUSB0
[ 19.049012] usb 1-2: Detected FT4232H
[ 19.053965] usb 1-2: FTDI USB Serial Device converter now attached to ttyUSB1
[ 19.068200] usb 1-2: Detected FT4232H
[ 19.073629] usb 1-2: FTDI USB Serial Device converter now attached to ttyUSB2
[ 19.093519] usb 1-2: Detected FT4232H
[ 19.098481] usb 1-2: FTDI USB Serial Device converter now attached to ttyUSB3
[ 30.513062] usb0: HOST MAC be:69:b9:83:6d:2a
[ 30.513066] usb0: MAC be:69:b9:83:6d:2b
[ 30.525626] l4tbr0: port 2(usb0) entered blocking state
[ 30.525638] l4tbr0: port 2(usb0) entered disabled state
[ 30.525757] device usb0 entered promiscuous mode
there is no fusb302 related settings on the board and also i have disabled in the device tree.
Please check the device tree compiled.dts.txt (419.3 KB)
dump message:
[ 1.588887] usbcore: registered new interface driver usbfs
[ 1.594380] usbcore: registered new interface driver hub
[ 1.599698] usbcore: registered new device driver usb
[ 4.299729] usbcore: registered new interface driver r8152
[ 4.305360] usbcore: registered new interface driver asix
[ 4.310906] usbcore: registered new interface driver ax88179_178a
[ 4.317162] usbcore: registered new interface driver cdc_ether
[ 4.323146] usbcore: registered new interface driver net1080
[ 4.328949] usbcore: registered new interface driver cdc_subset
[ 4.335027] usbcore: registered new interface driver zaurus
[ 4.340757] usbcore: registered new interface driver cdc_ncm
[ 4.346572] usbcore: registered new interface driver aqc111
[ 4.368983] tegra-xusb 3610000.xhci: Adding to iommu group 0
[ 4.375331] usbcore: registered new interface driver uas
[ 4.380810] usbcore: registered new interface driver usb-storage
[ 4.398958] usbcore: registered new interface driver xpad
[ 5.715667] usbcore: registered new interface driver usbhid
[ 5.721397] usbhid: USB HID core driver
[ 6.129200] usbcore: registered new interface driver snd-usb-audio
[ 7.387928] tegra-xusb 3610000.xhci: Firmware timestamp: 2023-02-10 03:48:10 UTC, Version: 80.05 release
[ 7.397682] tegra-xusb 3610000.xhci: xHCI Host Controller
[ 7.403300] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 1
[ 7.411949] tegra-xusb 3610000.xhci: hcc params 0x0180ff05 hci version 0x120 quirks 0x0000000000050810
[ 7.421554] tegra-xusb 3610000.xhci: irq 229, io mem 0x03610000
[ 7.427997] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[ 7.436500] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 7.443927] usb usb1: Product: xHCI Host Controller
[ 7.448933] usb usb1: Manufacturer: Linux 5.10.120OrinDRM+ xhci-hcd
[ 7.455366] usb usb1: SerialNumber: 3610000.xhci
[ 7.469120] tegra-xusb 3610000.xhci: xHCI Host Controller
[ 7.474674] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 2
[ 7.482458] tegra-xusb 3610000.xhci: Host supports USB 3.1 Enhanced SuperSpeed
[ 7.489967] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
[ 7.498472] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 7.505897] usb usb2: Product: xHCI Host Controller
[ 7.510900] usb usb2: Manufacturer: Linux 5.10.120OrinDRM+ xhci-hcd
[ 7.517337] usb usb2: SerialNumber: 3610000.xhci
[ 7.721902] usb 1-2: new high-speed USB device number 2 using tegra-xusb
[ 7.879425] usb 1-2: New USB device found, idVendor=0403, idProduct=6011, bcdDevice= 8.00
[ 7.887839] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 7.895184] usb 1-2: Product: Quad RS232-HS
[ 7.899476] usb 1-2: Manufacturer: FTDI
[ 8.106050] usb 1-3: new high-speed USB device number 3 using tegra-xusb
[ 8.270032] usb 1-3: New USB device found, idVendor=0781, idProduct=55ab, bcdDevice= 1.00
[ 8.278448] usb 1-3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 8.285791] usb 1-3: Product: SanDisk 3.2Gen1
[ 8.290352] usb 1-3: Manufacturer: USB
[ 8.294291] usb 1-3: SerialNumber: 0401560f40952dbc0e3436df992295ab6675723839beef3157b08d7291ecd0dd91ef00000000000000000000fee19030008c2a18ab558107562ee5c1
[ 8.309580] usb-storage 1-3:1.0: USB Mass Storage device detected
[ 8.316661] scsi host0: usb-storage 1-3:1.0
[ 19.819514] usbcore: registered new interface driver ftdi_sio
[ 19.825496] usbserial: USB Serial support registered for FTDI USB Serial Device
[ 19.839948] usb 1-2: Detected FT4232H
[ 19.844983] usb 1-2: FTDI USB Serial Device converter now attached to ttyUSB0
[ 19.859236] usb 1-2: Detected FT4232H
[ 19.864260] usb 1-2: FTDI USB Serial Device converter now attached to ttyUSB1
[ 19.880379] usb 1-2: Detected FT4232H
[ 19.885351] usb 1-2: FTDI USB Serial Device converter now attached to ttyUSB2
[ 19.900255] usb 1-2: Detected FT4232H
[ 19.905233] usb 1-2: FTDI USB Serial Device converter now attached to ttyUSB3
[ 30.585868] usb0: HOST MAC be:69:b9:83:6d:2a
[ 30.585870] usb0: MAC be:69:b9:83:6d:2b
[ 30.596727] l4tbr0: port 2(usb0) entered blocking state
[ 30.596739] l4tbr0: port 2(usb0) entered disabled state
[ 30.597019] device usb0 entered promiscuous mode
