DLA usage percentage and frequency reporting in tegrastats tool
I run the tegrastats tool to collect performance statistics while my deepstream gst pipeline is running on Jetson AGX Orin . The pipeline has the inferencing enabled to run with DLA. When i checked the the tegrastats output, i noticed it has metric about DLA (as below). The metric mentioned DLA frequency but it seems to me that the DLA usage percentage is missing before the “@” symbol. Is this expected? i’m looking for way to check the usage percentage of DLA similar to the GPU metric reported by tegrastats tool.
“NVDLA0_FREQ @1536
snippet from my tegrastats log:
06-01-2022 16:33:06 RAM 6327/30623MB (lfb 5561x4MB) SWAP 0/15311MB (cached 0MB) CPU [11%@2199,5%@2200,3%@2198,11%@2199,3%@2198,1%@2195,0%@2198,1%@2199,1%@2198,1%@2199,1%@2102,3%@2197] EMC_FREQ 28%@3199 GR3D_FREQ 22%@1300 GR3D2_FREQ 22%@1300 NVENC 998 NVDEC 998 NVJPG1 729 VIC_FREQ 39%@729 NVDLA0_FREQ @1536 APE 233 CV0@56.375C CPU@58.937C Tdiode@47C SOC2@55.218C SOC0@56.312C CV1@55.593C GPU@53.875C SOC1@55.187C CV2@51.875C VDD_GPU_SOC 13178mW/13178mW VDD_CPU_CV 3993mW/3993mW VIN_SYS_5V0 7975mW/7975mW NC 0mW/0mW VDDQ_VDD2_1V8AO 2120mW/2120mW NC 0mW/0mW
Which JetPack version do you use?
We don’t get the NVDLA0_FREQ from tegrastat on Orin with JetPack 5.0.1.
$ sudo tegrastats
06-02-2022 09:40:53 RAM 2872/30623MB (lfb 5315x4MB) SWAP 0/15311MB (cached 0MB) CPU [0%@729,0%@730,1%@718,0%@731,0%@730,0%@727,0%@723,0%@729,0%@729,0%@728,0%@730,0%@751] EMC_FREQ 0%@204 GR3D_FREQ 0%@114 GR3D2_FREQ 0%@114 NVJPG1 729 VIC_FREQ 729 APE 233 CV0@-256C CPU@49.468C Tdiode@39.75C SOC2@46.031C SOC0@46.781C CV1@-256C GPU@44.781C SOC1@45.5C CV2@-256C VDD_GPU_SOC 4592mW/4592mW VDD_CPU_CV 765mW/765mW VIN_SYS_5V0 3931mW/3931mW NC 0mW/0mW VDDQ_VDD2_1V8AO 704mW/704mW NC 0mW/0mW
As far as I realized, the power consumption of DLA is reported at the end of the tegrastats, which corresponds to NC 0mW/0mW in your output.
I suggest you run tegrastats just a few seconds before running the DLA part in your execution so that you can see the difference in the power consumption.
Yeap…i’m using JetPack 5.0.1 DP on my AGX Orin 32GB HW.
Attached are my main DS config file and gie config file for your reference.
deepstream-main-config-DLA.txt (1.7 KB)
config_infer_primary_gie-dla.txt (1.0 KB)
i enabled the following property in my gie config file.
enable-dla=1
use-dla-core=0
Also, i used deepstream-app (with Yolo custom plugin, weight and config from GitHub - marcoslucianops/DeepStream-Yolo: NVIDIA DeepStream SDK 6.1 / 6.0.1 / 6.0 configuration for YOLO models) to generate the TRT engine model for my Yolo v3 model to be run with DLA and then set the “model-engine-file” property in the gie config file to point to the generated engine mode.
You can get the DLA status with the following command (active/suspended).
Does this meet your requirement?
$ watch -n 1 "cat /sys/devices/platform/host1x/15880000.nvdla0/power/runtime_status"
$ watch -n 1 "cat /sys/devices/platform/host1x/158c0000.nvdla1/power/runtime_status"
That’s not what we are looking for. We are looking for utilization percentage reporting for DLA like how tegrastats reports the GPU utilization (eg: GR3D 22%@1300).
So does that mean the NVDLA0_FREQ reported by tegrastat which i have observed earlier on is unexpected and DLA metric reporting is not officially supported by tegrastat?
DLA only has the active/suspended status value.
