Hello
We are using vGPUs on SLES 15 VMs which are hosted in vSphere.
After updating the driver from 550.54.15 to 570.124.06 the VM it is unable to find a valid license file.
The gridd service shows the following status:
systemctl status nvidia-gridd.service
● nvidia-gridd.service - NVIDIA Grid Daemon
Loaded: loaded (/usr/lib/systemd/system/nvidia-gridd.service; enabled; preset: disabled)
Active: active (running) since Thu 2025-04-24 09:43:41 CEST; 2s ago
Process: 127154 ExecStart=/usr/bin/nvidia-gridd (code=exited, status=0/SUCCESS)
Main PID: 127155 (nvidia-gridd)
Tasks: 3 (limit: 65536)
CPU: 32ms
CGroup: /system.slice/nvidia-gridd.service
└─127155 /usr/bin/nvidia-gridd
Apr 24 09:43:41 myserver8663 systemd[1]: Starting NVIDIA Grid Daemon…
Apr 24 09:43:41 myserver8663 nvidia-gridd[127155]: Started (127155)
Apr 24 09:43:41 myserver8663 systemd[1]: Started NVIDIA Grid Daemon.
Apr 24 09:43:41 myserver8663 nvidia-gridd[127155]: vGPU Software package (0)
Apr 24 09:43:41 myserver8663 nvidia-gridd[127155]: Ignore service provider and node-locked licensing
Apr 24 09:43:41 myserver8663 nvidia-gridd[127155]: NLS initialized
Apr 24 09:43:42 myserver8663 nvidia-gridd[127155]: Failed to fetch config token from licenseserver0160.test.ch (Error: Missing required configuration. Please reinstall the license file.)
We are running vSphere Client version 7.0.3.01900
Hardware model: Unknown by me
VM OS: SLES 15 SP6
Feature type: NVIDIA RTX Virtual Workstation
GPU model: L40
I don’t have access to our DLS Server
What we have tried so far:
Get a new ClientConfigToken → Did not help
Downgrade driver to 550.54.15 with new token → License can be aquired by server
Update to 570.124.06 again → No License can be aquired again
Update DLS Server → did not help
Update the driver on the ESX Hosts → Did not help
Update to driver 570.133.20 → Did not help
I don’t know if im missing a change in licensing in the release notes between driver 550.54.15 and 570.133.20 but by looking at the Virtual GPU Software Client Licensing Use Guide the Licesing seems to be unchanged.
The error seems to be pretty straight forward “Missing required configuration. Please reinstall the license file.” which we tried by getting a new Token and required configuation is already there, othererwise it would not have worked before the upgrade to the new driver.
What am I missing?
