Do the display ports on the Xavier support Multi-Stream Transport (MST)?
I am wondering if the display ports on the Xavier developer kit support the MST feature of the Display Port standard (see [url]DisplayPort - Wikipedia). I would like to attach two displays to one of the outputs (either USB-C or HDMI) via a MST hub.
Does anyone have experience with this? If so, what combination of adapters and hardware (displays) did you use, and was it supported in JetPack 4.2?
Thanks for the help.
No, currently it is not supported. I’ve filed this as a feature request.
I second that feature request.
Per checked with our internal team. MST is not supported by Tegra SoC currently. I mean even from hardware side, it is not supported.
