DOCA Comch execution error
Hi, I have tried to execute DMA Copy application on my BF2 following application guide, but faced error below.
There are two libraries leveraged in the application, DMA and Comch. I also tried to execute each sample of the libraries, and faced the same error with Comch sample (DMA sample works well). How can I fix it?
DOCA version on BF2:
DOCA SDK Version (Compilation): 2.8.0081
DOCA Runtime Version (Runtime): 2.8.0081
DOCA version on host:
DOCA SDK Version (Compilation): 2.8.0082
DOCA Runtime Version (Runtime): 2.8.0082
Output on BF2:
/tmp/build/dma_copy/doca_dma_copy -p 03:00.0 -r 03:00.0 -f ~/received.txt
[23:50:43:372211][496685][DOCA][INF][comch_utils.c:464][comch_utils_fast_path_init] Server waiting on a client to connect
Error on host:
/tmp/build/dma_copy/doca_dma_copy -p 01:00.0 -f ~/send.txt
[08:48:16:635168][9190][DOCA][INF][dma_copy_core.c:110][validate_file_size] The file size is 13
[08:48:16:684453][9190][DOCA][ERR][linux_devx_obj.cpp:61][priv_doca_devx_object] Failed to create devx object with syndrome=0xe5300
[08:48:16:684613][9190][DOCA][ERR][doca_dev.cpp:2124][priv_doca_dev_devx_object_create] Failed to create devx object: failed to allocate devx object wrapper with exception:
[08:48:16:684646][9190][DOCA][ERR][doca_dev.cpp:2124][priv_doca_dev_devx_object_create] DOCA exception [DOCA_ERROR_DRIVER] with message DEVX object failed to create
[08:48:16:684667][9190][DOCA][ERR][cc_devx_2.cpp:282][cc_devx_2_register_channel_connection] Failed to create channel connection object with error DOCA_ERROR_DRIVER
[08:48:16:684681][9190][DOCA][ERR][qp_channel_2.cpp:1014][cc_2_qp_register_client] client registration failed for send side
[08:48:16:684695][9190][DOCA][ERR][doca_comm_channel_2.cpp:847][doca_comm_channel_2_ep_client_connect] client registration failed for doca_comm_channel_2_ep_client_connect()
[08:48:16:684708][9190][DOCA][ERR][doca_comch_pe.cpp:393][priv_doca_comch_pe_start_cb] failed to connect on client with error = DOCA_ERROR_CONNECTION_ABORTED
[08:48:16:691625][9190][DOCA][ERR][doca_pe.cpp:1054][start_context] Progress engine 0x55c5e127e300: Failed to start context=0x55c5e12814f0. err=DOCA_ERROR_CONNECTION_ABORTED
[08:48:16:691655][9190][DOCA][ERR][comch_utils.c:535][comch_utils_fast_path_init] Failed to start comch client context: Connection aborted
[08:48:16:692652][9190][DOCA][ERR][dma_copy.c:95][main] Failed to initialize a comch: Connection aborted
I have solved this problem by just updating the DOCA version (2.8 → 2.9).
I found this error also occurs if you try starting the dma_copy sample application on the host (x86) before starting it on the device (Bluefield-3). I wanted to add this because I was still encountering this error on DOCA 2.9.
Hi, I meet the same error and solve it due to the wrong representor PCI address. You can check my reply in this post BlueField-2 DPU can't find representor - #2 by yu.zhu2.
It works. ThankU!!
Same as a writer, i didn’t check rep <> PCI Mappings
