Docker_build_ml failed. "libcurand.so.10 caonnot open shared object file:
I am running JetPack 4.5 and downloaded the docker file for the machine learning library.
Running the script file “docker_build_ml.sh” it ran until step 15 of 22 with the following error:
Cloning into turchvision
You are in 'detached HEAD state.
OSERROR: libcurand.so.10" cannot open shared object file: no such file or directory.
Not sure of how to proceed.
Thank You
Tom
Hi @minertom11551, did you set your default docker runtime to nvidia, like shown here?
https://github.com/dusty-nv/jetson-containers#docker-default-runtime
Also, these containers for JetPack 4.5 are available on NGC prebuilt, you can find the links at the top of the readme here:
https://github.com/dusty-nv/jetson-containers#machine-learning-containers-for-jetson-and-jetpack
nvcr.io/nvidia/l4t-ml:r32.5.0-py3
nvcr.io/nvidia/l4t-pytorch:r32.5.0-pth1.7-py3
nvcr.io/nvidia/l4t-tensorflow:r32.5.0-tf1.15-py3
nvcr.io/nvidia/l4t-tensorflow:r32.5.0-tf2.3-py3
