bth
April 22, 2022, 8:13am
1
Hi
I’m currently testing out a new camera from Baumer (VAX32.C.I.NVN) wich has the jetson nano SOM.
They have provided a OS with L4T installed, when i check the version it says:
cat /etc/nv_tegra_release
# R32 (release), REVISION: 4.4, GCID: 23942405, BOARD: t210ref, EABI: aarch64, DATE: Fri Oct 16 19:44:43 UTC 2020
I would like to try the classification_interactive from the DLI (Getting Started with AI on Jetson Nano). I followed the toturial and as i understand my docker file sould be (to match the L4T version 4.4):
JetPack Release Container Version Tag Language
4.4 v2.0.0-r32.4.3 en-US
However when i try to import:
import torchvision.transforms as transforms
i get the following error:
OSError: libcurand.so.10: cannot open shared object file: No such file or directory
My docker command is:
sudo docker run --runtime nvidia -it --privileged --rm --network host --volume ~/nvdli-data:/nvdli-nano/data --volume /tmp/argus_socket:/tmp/argus_socket nvcr.io/nvidia/dli/dli-nano-ai:v2.0.0-r32.4.3
Ive added --privileged to allow access to speak with the Baumer camera module.
Can anyone help resolve this issue?
Thanks in advance!
bth
April 22, 2022, 8:18am
2
Full error readout:
OSError Traceback (most recent call last)
<ipython-input-1-413b1040f905> in <module>
----> 1 import torchvision.transforms as transforms
2 from dataset import ImageClassificationDataset
3
4 TASK = 'thumbs'
5 # TASK = 'emotions'
/usr/local/lib/python3.6/dist-packages/torchvision-0.7.0a0+6631b74-py3.6-linux-aarch64.egg/torchvision/__init__.py in <module>
3 from .extension import _HAS_OPS
4
----> 5 from torchvision import models
6 from torchvision import datasets
7 from torchvision import ops
/usr/local/lib/python3.6/dist-packages/torchvision-0.7.0a0+6631b74-py3.6-linux-aarch64.egg/torchvision/models/__init__.py in <module>
----> 1 from .alexnet import *
2 from .resnet import *
3 from .vgg import *
4 from .squeezenet import *
5 from .inception import *
/usr/local/lib/python3.6/dist-packages/torchvision-0.7.0a0+6631b74-py3.6-linux-aarch64.egg/torchvision/models/alexnet.py in <module>
2 import torch.nn as nn
3 from .utils import load_state_dict_from_url
4
5
/usr/local/lib/python3.6/dist-packages/torch/__init__.py in <module>
186 # See Note [Global dependencies]
187 if USE_GLOBAL_DEPS:
--> 188 _load_global_deps()
189 from torch._C import *
190
/usr/local/lib/python3.6/dist-packages/torch/__init__.py in _load_global_deps()
139 lib_path = os.path.join(os.path.dirname(here), 'lib', lib_name)
140
--> 141 ctypes.CDLL(lib_path, mode=ctypes.RTLD_GLOBAL)
142
143
/usr/lib/python3.6/ctypes/__init__.py in __init__(self, name, mode, handle, use_errno, use_last_error)
346
347 if handle is None:
--> 348 self._handle = _dlopen(self._name, mode)
349 else:
350 self._handle = handle
bth
April 22, 2022, 9:29am
3
From inside the container:
root@varo-desktop:~# ll /usr/local/cuda/lib64/
total 1444
drwxr-xr-x 1 root root 4096 Jun 27 2020 ./
drwxr-xr-x 1 root root 4096 Jun 27 2020 ../
-rw-r--r-- 1 root root 677036 Jun 27 2020 libcudadevrt.a
-rw-r--r-- 1 root root 786194 Jun 27 2020 libcudart_static.a
drwxr-xr-x 2 root root 4096 Jun 27 2020 stubs/
Outside the container:
varo@varo-desktop:~$ ll /usr/local/cuda/lib64/
ls: cannot access '/usr/local/cuda/lib64/': No such file or directory
bth
April 22, 2022, 12:45pm
4
As per my last reply i realized that i needed cuda installed properly, and following the steps from:
https://forums.developer.nvidia.com/t/oserror-libcurand-so-10-cannot-open-shared-object-file-no-such-file-or-directory-when-running-from-l4t-image/198578/5?u=bth
I ran following:
sudo apt-get update && sudo apt-get install cuda-toolkit-10-2
export LD_LIBRARY_PATH=/usr/local/cuda-10.2/lib64:$LD_LIBRARY_PATH
sudo apt install nvidia-container-csv-cuda
sudo apt install nvidia-container-csv-cudnn
That resolved my issues.
If anyone else are trying out the Baumer camera, i have written a camera file similar to usb_camera.py that works with jetcam, so that the training in the DLI course can be run with the built in camera.
kayccc
April 24, 2022, 10:50pm
5
Gald to know issue fixed, thanks for the update.
