Hey,
I am using L4T 32.4.3 on a TX2:
root@localhost:/# cat /etc/nv_tegra_release
# R32 (release), REVISION: 4.3, GCID: 21589087, BOARD: t186ref, EABI: aarch64, DATE: Fri Jun 26 04:34:27 UTC 2020
After installing docker:
$ curl -s -L https://nvidia.github.io/nvidia-docker/gpgkey | sudo apt-key add -
$ distribution=$(. /etc/os-release;echo $ID$VERSION_ID)
$ curl -s -L https://nvidia.github.io/nvidia-docker/$distribution/nvidia-docker.list | sudo tee /etc/apt/sources.list.d/nvidia-docker.list
$ sudo apt-get update
$ sudo apt-get install -y nvidia-docker2
$ sudo pkill -SIGHUP dockerd
I download and run one of NVidias images:
$ docker -v
Docker version 20.10.21, build 20.10.21-0ubuntu1~18.04.2
$ sudo docker pull nvcr.io/nvidia/l4t-pytorch:r32.4.3-pth1.6-py3
$ docker run -it --rm --runtime nvidia --network host nvcr.io/nvidia/l4t-pytorch:r32.4.3-pth1.6-py3
Now I got the problem the inside the container torch does not find libcurand.so:
root@localhost:/# python3
Python 3.6.9 (default, Apr 18 2020, 01:56:04)
[GCC 8.4.0] on linux
Type "help", "copyright", "credits" or "license" for more information.
>>> import torch
File "<stdin>", line 1, in <module>
File "/usr/local/lib/python3.6/dist-packages/torch/__init__.py", line 188, in <module>
_load_global_deps()
File "/usr/local/lib/python3.6/dist-packages/torch/__init__.py", line 141, in _load_global_deps
ctypes.CDLL(lib_path, mode=ctypes.RTLD_GLOBAL)
File "/usr/lib/python3.6/ctypes/__init__.py", line 348, in __init__
self._handle = _dlopen(self._name, mode)
OSError: libcurand.so.10: cannot open shared object file: No such file or directory
But there is libcurand.so:
root@localhost:~# ls /usr/local/cuda-10.2/lib64/*curand*
/usr/local/cuda-10.2/lib64/libcurand.so.10 /usr/local/cuda-10.2/lib64/libcurand.so.10.1.2.89
What could be the problem?
R.
