Software Version
DRIVE OS 6.0.8.1
DRIVE OS 6.0.6
DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
Host Machine Version
other
I’m trying to use the docker method to install 6.0.8.1 with flash.py. I encountered the following error:
root@6.0.8.1-0006-build-linux-sdk:/drive# ./flash.py /dev/ttyACM1 p3710
2023-10-23 22:47:06 INFO : Flashing already set for dual bootchain
2023-10-23 22:47:06 INFO : Flash clean already disabled for persistent partitions
2023-10-23 22:47:06 INFO : Initiating pre-flash check
2023-10-23 22:47:06 INFO : Checking Serial Port Connection
2023-10-23 22:47:06 INFO : Serial Port found /dev/ttyACM1
2023-10-23 22:47:06 INFO : Running basic open/close tests on Serial Port Connection
2023-10-23 22:47:06 INFO : Serial Port is open
2023-10-23 22:47:06 INFO : Flushing input and output buffer, discard all content
2023-10-23 22:47:06 INFO : Serial Port is closed
2023-10-23 22:47:06 INFO : Checking available targets
2023-10-23 22:47:06 INFO : Checking Orin board connection
2023-10-23 22:47:06 INFO : Orin board with Device ID -- 0955:7045 found.
2023-10-23 22:47:06 INFO : Orin board device path is /dev/bus/usb/003/004
2023-10-23 22:47:06 INFO : Pre-flash check complete
2023-10-23 22:47:06 INFO : Flashing DRIVE OS Docker
2023-10-23 22:47:10 INFO : driveinstaller v2.0
2023-10-23 22:47:10 INFO : SDK/PDK Installer and Flasher
2023-10-23 22:47:10 INFO : Run `./driveinstaller --help` for usage information.
2023-10-23 22:47:10 INFO : Initializing board and OS configuration to Autonomous vehicle p3710 Linux Tegra A
2023-10-23 22:47:10 INFO : Manifest version 2.0
2023-10-23 22:47:10 INFO : Could not fetch board revision. Re-try either by re-connecting board or make sure all serial port processes such as minicom are closed.
2023-10-23 22:47:10 INFO : Failed to bind partitions!
2023-10-23 22:47:10 INFO : driveinstaller cannot continue! Check the log file for details: /drive/driveinstaller/driveinstaller.log
2023-10-23 22:47:10 ERROR : Flashing failed, please contact provider with logs /drive_flashing/log_kui30bjxvz5nrpo9gw47a6y182qcslmd.txt and /drive/driveinstaller/driveinstaller.log.
The logs are as follows.
driveinstaller.log (545.6 KB)
log_kui30bjxvz5nrpo9gw47a6y182qcslmd.txt (1.4 KB)
Can you please help?
