Failure to flash AGX Orin Dev kit
Software Version
DRIVE OS 6.0.8.1
DRIVE OS 6.0.6
DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.9.3.10904
other
Host Machine Version
other
We are trying to flash the AGX Orin Dev Kit P3710 using the docker image as detailed in the page Finalize DRIVE AGX Orin System Setup | NVIDIA Docs. When running the command “./flash.py /dev/ttyACM1 p3710” the flashing starts, the serial port is found and an orin board with a device ID is detected. However when it reaches the point where ./driveinstallet starts it breaks. It tells us that it cannot fetch board revision and that it fails to bind partitions. We have rebooted both target and host afterwards but the same error persists. Also, after the flashing we can not long connect to the Aurix chip. The logs which ask us to contact you at Nvidia are attached.
failure_to_flash.txt (1.4 KB)
Thanks in advance.
Please provide the logs mentioned as follows:
2024-04-25 12:25:35 INFO : driveinstaller cannot continue! Check the log file for details: /drive/driveinstaller/driveinstaller.log
2024-04-25 12:25:35 ERROR : Flashing failed, please contact provider with logs /drive_flashing/log_74bdlfyarhxuc195osz8je2kvin6g3p0.txt and /drive/driveinstaller/driveinstaller.log.
