Docker Pull
I pulled the a docker repository for ROS using command:
$ docker pull dustynv/ros:humble-desktopl-l4t-r32.7.1
Got permission denied while trying to connect to the Docker daemon socket at unix:///var/run/docker.sock: Post http://%2Fvar%2Frun%2Fdocker.sock/v1.24/images/create?fromImage=dustynv%2Fros&tag=humble-desktopl-l4t-r32.7.1: dial unix /var/run/docker.sock: connect: permission denied.
Hiow do I resolve permission denied problem??
Thanks for your assistance !
Bob
Please run the command with sudo.
For example:
$ sudo docker pull dustynv/ros:humble-desktopl-l4t-r32.7.1
