I can't pull dockerI can't pull docker
Jetson Orin NX
L4T: 35.3.1
JetPack: 5.1.1
I’ll use the command to repeat
1.
nvidia@nvidia-desktop:~$ docker login nvcr.io
Username: $oauthtoken
Password:
Error response from daemon: Get “https://nvcr.io/v2/”: read tcp 192.168.3.213:48136->52.25.170.47:443: read: connection reset by peer
2.
nvidia@nvidia-desktop:~$ sudo docker pull nvcr.io/nvidia/l4t-tensorflow:r35.3.1-tf2.11-py3
Error response from daemon: Get “https://nvcr.io/v2/”: read tcp 192.168.3.213:39434->34.208.76.254:443: read: connection reset by peer
We can pull the container without issue.
This looks more like a connection issue.
Would you mind trying it again?
Could you try to pull other public containers to see if it works?
For example:
$ sudo docker pull ubuntu
