I get the Riva Speech Skill docker image path: nvcr.io/nvidia/riva/riva-speech:2.8.1
It doenst load the model and the bin file only has 2 executables: start-riva and riva_server
I am confused since I cant find any reference on the documentation.
Hi @Pappachuck_renan where do you have your models?
The riva_start.sh under the hood launches this:
docker run -d \
--init \
--gpus '"'$gpus_to_use'"' \
-p $riva_speech_api_port:$riva_speech_api_port \
-e "LD_PRELOAD=$ld_preload" \
-e "RIVA_API_KEY=$RIVA_API_KEY" \
-e "RIVA_API_NGC_ORG=$RIVA_API_NGC_ORG" \
-e "RIVA_EULA=$RIVA_EULA" \
-v $riva_model_loc:/data \
$ssl_vol_args \
--ulimit memlock=-1 --ulimit stack=67108864 \
--name $riva_daemon_speech $docker_run_args
Models are in $riva_model_loc variable path and then mounted inside the docker in /data. Can you check that inside /data you have the models and it is not empty?
Then try to launch
start-riva \
--riva-uri=0.0.0.0:50051 \
--asr_service=true \
--tts_service=true \
--nlp_service=true
To start riva server.
If you are still having problems you can paste all the container log using the docker logs command.
Regards!
Thanks for your interest in Riva
Thank you so much @jlamperez10 for your kind help and inputs, really appreciate
@Pappachuck_renan are you trying to setup and start using the quickstart guide
https://docs.nvidia.com/deeplearning/riva/user-guide/docs/quick-start-guide.html
Were bash riva_init.sh and bash riva_start.sh successful
We found the error:
riva-trt-conformer-en-US-asr-streaming-am-streaming
You must remove from production until fixed.
