I met a error when run the cmd
docker run --gpus all nvcr.io/nvidia/k8s/cuda-sample:nbody nbody -gpu -benchmark
the log is :
Unable to find image ‘nvcr.io/nvidia/k8s/cuda-sample:nbody’ locally
nbody: Pulling from nvidia/k8s/cuda-sample
22dc81ace0ea: Pull complete
1a8b3c87dba3: Pull complete
91390a1c435a: Pull complete
07844b14977e: Pull complete
b78396653dae: Pull complete
95e837069dfa: Pull complete
fef4aadda783: Pull complete
343234bd5cf3: Pull complete
d1e57bfda6f0: Pull complete
c67b413dfc79: Pull complete
529d6d22ae9f: Pull complete
d3a7632db2b3: Pull complete
4a28a573fcc2: Pull complete
71a88f11fc6a: Pull complete
11019d591d86: Pull complete
10f906646436: Pull complete
9b617b771963: Pull complete
6515364916d7: Pull complete
Digest: sha256:aaca690913e7c35073df08519f437fa32d4df59a89ef1e012360fbec46524ec8
Status: Downloaded newer image for nvcr.io/nvidia/k8s/cuda-sample:nbody
docker: Error response from daemon: cgroups: cannot find cgroup mount destination: unknown.
ERRO[0920] error waiting for container: context canceled
I solved the problem:
sudo mkdir /sys/fs/cgroup/systemd
sudo mount -t cgroup -o none,name=systemd cgroup /sys/fs/cgroup/systemd
Then it is OK
Run “nbody -benchmark [-numbodies=]” to measure performance.
-fullscreen (run n-body simulation in fullscreen mode)
-fp64 (use double precision floating point values for simulation)
-hostmem (stores simulation data in host memory)
-benchmark (run benchmark to measure performance)
-numbodies= (number of bodies (>= 1) to run in simulation)
-device= (where d=0,1,2… for the CUDA device to use)
-numdevices= (where i=(number of CUDA devices > 0) to use for simulation)
-compare (compares simulation results running once on the default GPU and once on the CPU)
-cpu (run n-body simulation on the CPU)
-tipsy=<file.bin> (load a tipsy model file for simulation)
NOTE: The CUDA Samples are not meant for performance measurements. Results may vary when GPU Boost is enabled.
Windowed mode
Simulation data stored in video memory
Single precision floating point simulation
1 Devices used for simulation
MapSMtoCores for SM 7.5 is undefined. Default to use 64 Cores/SM
GPU Device 0: “GeForce RTX 2080 Ti” with compute capability 7.5
Compute 7.5 CUDA device: [GeForce RTX 2080 Ti]
69632 bodies, total time for 10 iterations: 112.123 ms
= 432.438 billion interactions per second
= 8648.765 single-precision GFLOP/s at 20 flops per interaction
