I found the Out-of-Order Data Placement only described in Infiniband network, but not mentioned in RoCEv2 Ethernet mode. I want to know if it is supported in ROCEv2 mode for mellanox CX7 or CX8?
If it support, How to enable it? Thanks a lot!
If not use mellanox’s switch, only use the nic, is it supportted?
Hi 906787108,
Thank you for posting your query on NVIDIA Community.
If the question relates to the out of sequence counter found under sysfs(hardware counters), I would like to inform that although the path shows infiniband, it is also applicable to ETH interfaces as long as you are using MLNX OFED/ DOCA OFED drivers.
For example, here is an output from my internal lab system that has a ConnectX-7 ETH interface with DOCA OFED
root@hostname:~# ofed_info -s
OFED-internal-25.10-1.7.1:
root@hostname:~# mst status -v
MST modules:
MST PCI module is not loaded
MST PCI configuration module loaded
PCI devices:
DEVICE_TYPE MST PCI RDMA NET NUMA VFIO
ConnectX7(rev:0) /dev/mst/mt4129_pciconf1 c2:00.0 mlx5_1 net-ibs6 1
ConnectX7(rev:0) /dev/mst/mt4129_pciconf0 42:00.0 mlx5_0 net-ens3np0 0
root@hostname:~# cat /sys/class/infiniband/mlx5_0/ports/1/hw_counters/out_of_buffer
0
root@hostname:~# cat /sys/class/infiniband/mlx5_0/ports/1/hw_counters/out_of_sequence
0
Thanks,
NVEX Networking Technical Support.
