Does DeepStream nvinfer support tiled inference on large video frames?
• Hardware Platform (Jetson / GPU) 3090RTX
• DeepStream Version 9.0
• TensorRT Version deepstream 9.0 installation guide
• NVIDIA GPU Driver Version (valid for GPU only) 590
I am using NVIDIA DeepStream with the nvinfer plugin for object detection on MP4 video.
My model was trained for aerial imagery and expects relatively small inputs, for example 300×300 pixels. For large video frames such as 1920×1080, I would like to divide each frame into multiple overlapping tiles, run inference on every tile, convert each detection back to the original frame coordinates, and then apply NMS to remove duplicate detections from overlapping tiles.
The intended workflow is:
  1. Split the original frame into overlapping 300×300 tiles.
  2. Run the same detector on each tile.
  3. Convert bounding boxes from tile coordinates to full-frame coordinates.
  4. Merge all detections.
  5. Apply class-wise NMS to remove duplicates.
Does the standard DeepStream nvinfer plugin support this type of tiled inference directly?
For example, is there any configuration option in nvinfer for:
  • splitting one frame into several overlapping crops,
  • batching those crops for inference,
  • restoring detections to the original frame coordinates,
  • and merging duplicate detections?
Or do I need to implement this manually using a custom GStreamer plugin, nvdspreprocess, custom metadata, or multiple nvinfer inputs?
I would also appreciate any recommended DeepStream architecture for implementing tiled inference efficiently on GPU.
Thank you.
Hi, the nvpreprocess plugin ROI function may help you to fulfill such purpose. Gst-nvdspreprocess — DeepStream documentation
New plugins have been developed by a community contributor (shared in a previous topic by the creator).
The Github repository is : GitHub - levipereira/deepstream-sahi: Native GStreamer plugins that integrate SAHI (Slicing Aided Hyper Inference) into NVIDIA DeepStream for real-time small object detection in high-resolution video streams. · GitHub
Best regards,
Henri
