• Hardware Platform (Jetson / GPU) ---- RTX 2080 Ti
• DeepStream Version ---- DeepStream SDK 6.3
• JetPack Version (valid for Jetson only) ---- NA
• TensorRT Version ---- 8.6.1.6
• NVIDIA GPU Driver Version (valid for GPU only) ---- 530.30.02 (CUDA 12.1)
• Issue Type( questions, new requirements, bugs) ---- questions or bugs. Not sure yet
git clone https://github.com/NVIDIA-AI-IOT/deepstream-occupancy-analytics.gitgit log
commit ec56c72c777c76581734633fab12348b8e5ff4a9 (HEAD -> master, origin/master, origin/HEAD)
Merge: b3430e7 282e3c8
Author: monjha <monika.jhuria@gmail.com>
Date: Mon Jul 17 12:56:24 2023 -0700
Merge pull request #69 from 0ct0cat/deepstream-6.2
suppport deepstream-6.2 **<-- Does it mean that DS 6.3 is not yet supported?**
- Copy the directory deepstream-occupancy-analytics/ to deepstream/sources/apps/sample_apps/
- Follow deepstream-occupancy-analytics/README to download the pre-requirements and to build the code.
(I needed to add this line into deepstream-occupancy-analytics/Makefile:
CFLAGS+= -I/usr/include/gstreamer-1.0 -I/usr/include/glib-2.0 -I/usr/lib/x86_64-linux-gnu/glib-2.0/include
- Edit deepstream-occupancy-analytics/config/dstest_occupancy_analytics.txt to disable source1 and sink1.
- Edit deepstream-occupancy-analytics/config/nvdsanalytics_config.txt to redraw the Entry and Exit lines:
line-crossing-Exit=400;1050;450;850;50;850;850;850;
line-crossing-Entry=500;500;450;700;50;700;850;700
./deepstream-test5-analytics -c config/dstest_occupancy_analytics.txt- The sample app runs. People are crossing the lines (visual checking), but line crossing counters are not updated, as shown below:
• Requirement details( This is for new requirement. Including the module name-for which plugin or for which sample application, the function description) ---- Unsure if it’s relevant.
