I would like to create a 6GHz WiFi link between my Jetson Orin Nano Devkit (running Jetpack 7.2) and my laptop. The Jetson will function as an access point, and the laptop as a client.
One of the few M.2 adapters that support 6GHz WiFi access point mode is Qualcomm QCNFA765.
Does Jetson Orin Nano Devkit support it? I haven’t found any info about it on this forum.
If it doesn’t, what is the cheapest way to link it to the laptop over 6GHz WiFi?
By default the WIFI module is
AzureWave RTL8822CE 802.11ac PCIe Wireless Network Adapter
For other modules, please check if any driver needs to be enabled. You can refer to developer guide to do kernel customization:
Kernel Customization — NVIDIA Jetson Linux Developer Guide
No data from Joystick Logitech-f710 - #10 by DaneLLL
May also refer to the list:
Wi-Fi 6/6E/7 modules that have been validated with AGX Orin devkits
