I read through the Jetson Orin Thermal Design Guide but couldn’t find this info.
Based on the provided context, it appears that you are looking for specific information related to the Jetson Orin NX series, but you couldn’t find it in the Jetson Orin Thermal Design Guide.
After reviewing the provided context, I found that the guide provides thermal specifications for the Jetson Orin module series, including the maximum operating temperature and shutdown temperature for the Orin SoC. However, it does not provide specific information on the Jetson Orin NX series alone.
Here are some key points that might be relevant to your query:
- Thermal Specifications: The guide provides thermal specifications for the Jetson Orin module series, including the maximum operating temperature (T.SoC3 = 99°C) and shutdown temperature (T.SoC3 = 105°C) for the Orin SoC.
- Jetson Orin NX Series: The guide mentions that the Jetson Orin NX series includes both the 16GB and 8GB variants, but it does not provide separate thermal specifications for each variant.
- Thermal Design Guidance: The guide provides design guidance for meeting the thermal specifications, including recommendations for thermal solutions, heat sinks, and thermal interfaces.
- Module Thermal Performance: The guide discusses the thermal performance of the Jetson Orin module, including the thermal resistance network and the importance of designing an adequate thermal solution to maintain component temperatures below the de-rated limits.
If you could provide more context or clarify what specific information you are looking for, I’ll do my best to help you find it.
Refer to Orin NX data sheet for operating temperature range Jetson Orin NX Series Modules Data Sheet https://developer.nvidia.com/downloads/jetson-orin-nx-module-series-data-sheet
Got it, so as long as during the system’s boot process the operating temperature is within spec, no matter the variance of temperature between the start of boot to boot completion, the system should operate normally?
Correct.
