We intend to use the Jetson Orin NX SOM for our project; the operating temperature for our product is -40 to 70 C, however the SOM datasheet only lists the SoC Tj as -25 to 105 C. Could you kindly clarify that the entire SOM (including the SoC, PMIC, and so on) can be run in this temperature range?
Thank you for the information , but still the table contains only the maximum temperature of each components, due you have any information regarding the minimum temperature limit as well.
