Does jetson orin nx support opencl?can I use opencl in jetson orin nx? if not support,if there are other methos that can run opencl in it?
By default it is not enabled on L4T release. Please check the community contribution and give it a try. You may search the keywords l4t opencl via search engine.
thank you for your reply firstiy ,you means jetson orin nx support opencl or not ,I can not find opencl
No, by default it is not enabled. You would need to search online to get more information. Or would see if other users can share experience.
