Does jetson xavier nx support 5 usb camera concurrent streaming?
I have a project where i have built a 5 cameras stitching pipeline. I am thinking to port it to jetson xavier nx. But as i know the i have two options for 5 cameras in jetson xavier nx.
  1. Go with the cam array for CSI port. (i found one from arducam cam array but heard that it doesn’t have drvier support). Any alternative suggestions?
  2. If opt. 1 doesn’t help , i am thinking to use 5 usb cameras with usb hub as an attachment. I would like to know if the jetson can be powerful enough (in terms of POWER) to stream 5 cameras . I have came across some post which mentioned the power may not be sufficient touse 5 cameras at a time.
    Camera usage specs : Logitech USB camera
    1280 x 1080 (30 fps) is the expected resolution of each camera. So help me in knowing if the jetson xavier NX (dev kit) is good enough with this.
Thanks ;)
The XNX support to 3 USB cameras.
what if i use powered-usb-hub ? Does it help in using more than 3 USB cameras?
I don’t think so.
