我们板子上,IX8000 USB口的USB_P1_D_P/N是GL3523 USBHUB过来,USBHUB上游接USB1,SS的4根线从USBSS0过来,这种接法USBSS0是否能作为USB3.0 device模式?
On our board, the USB_P1_D_P/N of the IX8000 USB port is connected from GL3523 USBHUB, with the upstream of USBHUB connected to USB1, and the four lines of SS are connected from USBSS0. Can this connection method allow USBSS0 to function as a USB3.0 device mode?
we don’t support this design. You could not use signal behind the hub to form another port.
Is it correct to understand that a USB device with only SS (SuperSpeed) and no D+/D- (Data+ / Data-) of USB 2.0 is not supported.
I am not sure why this question come out here as this seems not related to original problem…
We don’t support a non standard USB device as you mentioned.
