Does this mean the SPI device is OK at TX1 R28.1?
1.Does this mean the SPI device is OK at TX1 R28.1?
nvidia@tegra-ubuntu:~/spi$ lsmod
Module                  Size  Used by
bcmdhd               7675329  0
spidev                 11174  0
bluedroid_pm           13898  0
nvidia@tegra-ubuntu:~/spi$ ls /dev/spi*
/dev/spidev0.0  /dev/spidev1.0  /dev/spidev2.0  /dev/spidev3.0
nvidia@tegra-ubuntu:~/spi$ sudo cat /sys/kernel/debug/tegra_gpio
0:0 24 00 00 24 00 00 000000
0:1 0f 00 00 00 00 00 000000
0:2 00 00 00 00 00 00 000000
0:3 00 00 00 00 00 00 000000
1:0 70 00 00 60 00 00 000000
1:1 00 00 00 00 00 00 000000
1:2 00 00 00 00 00 00 000000
1:3 ff 1b 0b 40 00 24 002024
2:0 0f 0d 01 02 00 00 000000
2:1 00 00 00 00 00 00 000000
2:2 f0 20 00 d0 00 80 008000
2:3 02 00 00 02 00 00 000000
3:0 00 00 00 00 00 00 000000
3:1 00 00 00 00 00 00 000000
3:2 00 00 00 00 00 00 000000
3:3 00 00 00 00 00 00 000000
4:0 00 00 00 00 00 00 000000
4:1 00 00 00 00 00 00 000000
4:2 f0 f0 00 00 00 00 000000
4:3 03 03 00 00 00 00 000000
5:0 0c 00 00 08 00 00 000000
5:1 6e 66 00 00 00 00 000000
5:2 00 00 00 00 00 00 000000
5:3 ff 00 00 ff 00 70 606000
6:0 03 00 00 03 00 01 010100
6:1 1f 08 00 17 00 07 030300
6:2 00 00 00 00 00 00 000000
6:3 0d 04 00 00 00 00 000000
7:0 32 10 00 20 00 02 020200
7:1 00 00 00 00 00 00 000000
7:2 00 00 00 00 00 00 000000
7:3 00 00 00 00 00 00 000000
2.But I can not find the SPI CLK wave signal,WHY?
sudo ./spidev_test -D /dev/spidev0.0
sudo ./spidev_test -D /dev/spidev1.0
sudo ./spidev_test -D /dev/spidev2.0
sudo ./spidev_test -D /dev/spidev3.0
I use the PC0.0,PC0.1,PC0.2,PC0.3,PC0.4 to SPI pin.
How can I solve this problem?
Not sure if this comment send package?
Can you try have parameter for the data package.
What the parameter for the data package?
How can I send a large data pakage? for example ,50 bytes.
Download below execute binary and try “./spidev_test -D /dev/spidev0.1 -s1000000 -g8 -b8 -p0 -n1 -zzz -t”
[url]https://devtalk.nvidia.com/default/topic/1042605/jetson-tx1/does-this-spi-port-set-spi-mode-is-ok-at-tx1-r28-2-/post/5288547/#5288547[/url]
