jetson tx2 spidev
the jetson tx2 L4T version :R32.2.1
the spi pins :
SPI1_CLK G13
SPI1_MISO F14
SPI1_MOSI F13
SPI1_CS0 E13
my devicetree node is :
spi@3240000 {
    spi_qy@0 {
        compatible = "spidev";
                        reg = <0x0>;
                        spi-max-frequency = <0x1312d00>;
                        nvidia,enable-hw-based-cs;
                        nvidia,cs-setup-clk-count = <0x1e>;
                        nvidia,cs-hold-clk-count = <0x1e>;
                        nvidia,rx-clk-tap-delay = <0x1f>;
                        nvidia,tx-clk-tap-delay = <0x0>;
while I’m runing ./spidev_test -D /dev/spidev3.0
the RX is 00 00 00…
the ture should be FF FF …
at the L4T R28.2.1 the function is usefull.the hardware is well .
what should I do ? thanks
Have a reference to below topic.
hi ShaneCCC,
in the topic,we can see it’s solved by modifying the pinmux file.and the device is jetson xavier.
I saw the jetson tx2 in the bootloader/t186ref/BCT have the file,but I don’t know which one and what should I do to modify.
in the net ,most of the solution is to modify the device tree.This way I can not refresh the system.
Have a reference to below link.
https://devtalk.nvidia.com/default/topic/1056610/jetson-tx2/spi-config-on-tx2-r28-3/post/5357387/#5357387
what should I do to update the tegra186-mb1-bct-pinmux-quill-p3310-1000-c03.cfg file?
reflash the jetson tx2 system?
Yes modify the cfg file and reflash the system.
https://elinux.org/Jetson/TX2_SPI#Modifying_the_Pinmux_Configuration
Is there a way to not reflash the system?
You can use the devmem2 to write the REG before using SPI, however you have do it after system is reset every time.
thanks!
