I am trying to use the SPI Bus on the Devkit but am not able to get it working. I followed the steps here:
https://devtalk.nvidia.com/default/topic/1044595/jetson-agx-xavier/question-how-do-i-enable-and-address-spi-ports-/post/5307630/#5307630
The spidev module is loaded and I tried to send bytes via the python spidev library but I am not seeing any activity on the clk line using my oscilloscope.
Any ideas?
python code:
import spidev
spi = spidev.SpiDev()
spi.open(0, 0)
to_send = [0x01, 0x02, 0x03]
spi.xfer(to_send)
Could you try spidev_test utility.
kayccc
March 21, 2019, 5:36am
3
Hi pnewmanCTI,
Any update? Is this still an issue on you end?
I have same question.
The SPI1 is spidev0.0?
I modify the dts like below.
spi@xxxxxx {
status = "okay"; // Before change: "disable"
spidev@0 {
compatible = "spidev";
reg = <0>;
spi-max-frequency=<25000000>;
Should I modify the pinmux value??
We are still having this issue. I haven’t tried the new Jetpack yet though.
Have a reference to below link to check the pinmux.
I enable the spi1 and add spidev device node in dts. I can find the /dev/spidev0.0, but I can’t detect the signal with Logical Analysis. So, I want to know that the SPI1 is spidev0.0, right ?
Reading time: 4 mins 🕑
Likes: 1 ❤
I have my pinmux correct according to that thread but I am still not seeing anything on the clock or data lines…
