Xavier SPI1 use spidev_test.c issue
Hi guys,
finally, I enable the SPI1 on xavier.
firstly, I change the dts file to enable SPI1,
spi@c260000 {
		compatible = "nvidia,tegra186-spi";
		clocks = <0x4 0x88 0x4 0x5e 0x4 0x5b>;
		resets = <0x5 0x5c>;
		dma-coherent;
		clock-names = "spi", "pll_p", "osc";
		nvidia,clk-parents = "pll_p", "osc";
		status = "okay";
		#address-cells = <0x1>;
		interrupts = <0x0 0x25 0x4>;
		#size-cells = <0x0>;
		dma-names = "rx", "tx";
		phandle = <0x14b>;
		reg = <0x0 0xc260000 0x0 0x10000>;
		iommus = <0x2 0x20>;
		dmas = <0x1e 0x10 0x1e 0x10>;
		reset-names = "spi";
		linux,phandle = <0x14b>;
		spi-max-frequency = <0xb71b00>;
		spidev@0 {
			compatible = "spidev";
			reg = <0x0>;
			spi-max-frequency = <0x17d7840>;
and I flash the dtb to xavier and reboot it.
I can find spidev1.0 at /dev/, then I change the pinmux with devmem2 and the changed value is
Value at address 0x243D040 (0x7f88573040): 0x400
Value at address 0x243D020 (0x7fb70ec020): 0x450
Value at address 0x243D058 (0x7f9047a058): 0x400
Value at address 0x243D010 (0x7f7bfb8010): 0x400
Value at address 0x243D050 (0x7f78fd6050): 0x400
then I connect the MISO and MOSI of SPI1 of the extension header(p19 and p21)
x x
I connect the 2 x in the above picture.
but when I use spidev_test with
sudo ./spidev_test -v
the result is
xavier@xavier-desktop:~/Documents/tools/spi$ sudo ./spidev_test -v
spi mode: 0x0
bits per word: 8
max speed: 500000 Hz (500 KHz)
TX | FF FF FF FF FF FF 40 00 00 00 00 95 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF F0 0D  | ......@....�..................�.
RX | 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  | ................................
the receive data is not send data.
Can you find problem with my procedure?
Could you probe the signal to make sure of it?
thanks, Shane, do you mean to use an oscilloscope to show the MOSI signal?
I have another question about this, in this topic you say change the .cfg file can change the address
I find this file:tegra19x-mb1-pinmux-p2888-0000-a04-p2822-0000-b01.cfg
at nvidia_sdk/JetPack_4.2_Linux_P2888/Linux_for_Tegra/bootloader/t186ref/BCT
pinmux.0x0243d040 = 0x00000400; # spi1_sck_pz3: rsvd1, pull-down, tristate-enable, input-enable, lpdr-disable
pinmux.0x0243d020 = 0x00000450; # spi1_miso_pz4: rsvd1, pull-down, tristate-enable, input-enable, lpdr-disable
pinmux.0x0243d058 = 0x00000400; # spi1_mosi_pz5: rsvd1, pull-down, tristate-enable, input-enable, lpdr-disable
pinmux.0x0243d010 = 0x00000400; # spi1_cs0_pz6: rsvd1, pull-up, tristate-enable, input-enable, lpdr-disable
pinmux.0x0243d050 = 0x00000400; # spi1_cs1_pz7: rsvd1, pull-up, tristate-enable, input-enable, lpdr-disable
I modified it and use ./flash.sh -r -k kernel-dtb jetson-xavier mmcblk0p1
It doesn’t work, so I can only manually change the address value.
