Hi, I find a topic to talk about TX2 SPI usage.
I want to know does Xavier has a similar page like this at elinux
https://elinux.org/Jetson/TX2_SPI
If so, can you give me the link?
If not, does the process is fit Xavier in same way.
thanks.
thanks.
thanks, Shane
this topic you give is after SPI driver work.
does the SPI on the Xavier is default open?
to my opinion, I should do some kernel work first to enable the SPI, and then use the SPI_TEST
so the question is:
thank you very much for your patience
I find there are these steps to realize the SPI
1 Locating the SPI Pins
2 Building SPIDev Module
2.1 Downloading the Kernel Sources
2.2 Configuring the Kernel
2.3 Building the Kernel
2.4 Verifying SPIDev Module
3 Modifying the Device Tree
3.1 Installing DTC Tool
3.2 Decompiling Device Tree
3.3 Update The Device-Tree
3.4 Recompiling the Device Tree
3.5 Enabling the New DTB
4 Verifying SPIDev Device
