Signals (SCL) are high on Oscilloscope,but no any wave happened.
$ sudo ./spidev_test -v -s 65000000 -p 123456 -D /dev/spidev2.1
spi mode: 0x0
bits per word: 8
max speed: 65000000 Hz (65000 KHz)
speed 65000000
speed 65000000
TX | 31 32 33 34 35 36 __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ | 123456
RX | 00 00 00 00 00 00 __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ | …
test.c link:
kernel log:
[ 0.738329] iommu: Adding device 3210000.spi to group 8
[ 0.738730] iommu: Adding device 3230000.spi to group 9
[ 0.739130] iommu: Adding device 3270000.spi to group 10
[ 1.629040] qspi_mtd spi6.0: s25fs256s SSG 8 0 1000 2000000
[ 1.629078] qspi_mtd spi6.0: s25fs256s (32768 Kbytes)
[ 1.629109] qspi_mtd spi6.0: mtd .name = spi6.0, .size = 0x2000000 (32MiB) .erasesize = 0x00010000 (64KiB) .numeraseregions = 0
[ 1.629414] 1 ofpart partitions found on MTD device spi6.0
[ 1.629439] Creating 1 MTD partitions on "spi6.0":
[ 1196.282488] spi-tegra114 3230000.spi: CpuXfer ERROR bit set 0x1c00004
[ 1196.282611] spi-tegra114 3230000.spi: CpuXfer 0x47e01827:0x00000000
[ 1196.282686] spi-tegra114 3230000.spi: SPI_ERR: CMD_0: 0x47e01827, FIFO_STS: 0x01c00004
[ 1196.282766] spi-tegra114 3230000.spi: Error in Transfer
[ 1196.282820] spi_master spi2: failed to transfer one message from queue
[ 1196.282876] spi-tegra114 3230000.spi: SPI_ERR: DMA_CTL: 0x00000000, TRANS_STS: 0x40ff000c
[ 1260.075491] spi-tegra114 3230000.spi: CpuXfer ERROR bit set 0x400005
[ 1260.075519] spi-tegra114 3230000.spi: CpuXfer 0x43e01827:0x00000000
[ 1260.075540] spi-tegra114 3230000.spi: SPI_ERR: CMD_0: 0x43e01827, FIFO_STS: 0x00400005
[ 1260.075550] spi-tegra114 3230000.spi: Error in Transfer
[ 1260.075562] spi-tegra114 3230000.spi: SPI_ERR: DMA_CTL: 0x00000000, TRANS_STS: 0x40ff0000
[ 1260.075568] spi_master spi2: failed to transfer one message from queue
[ 1293.154611] spi-tegra114 3210000.spi: CpuXfer ERROR bit set 0x400005
[ 1293.154635] spi-tegra114 3210000.spi: CpuXfer 0x43e01827:0x00000000
[ 1293.154656] spi-tegra114 3210000.spi: SPI_ERR: CMD_0: 0x43e01827, FIFO_STS: 0x00400005
[ 1293.154661] spi-tegra114 3210000.spi: Error in Transfer
[ 1293.154676] spi_master spi0: failed to transfer one message from queue
[ 1293.154689] spi-tegra114 3210000.spi: SPI_ERR: DMA_CTL: 0x00000000, TRANS_STS: 0x40ff0000
[ 1317.776203] spi-tegra114 3210000.spi: CpuXfer ERROR bit set 0x400005
[ 1317.776231] spi-tegra114 3210000.spi: CpuXfer 0x47e01827:0x00000000
[ 1317.776252] spi-tegra114 3210000.spi: SPI_ERR: CMD_0: 0x47e01827, FIFO_STS: 0x00400005
[ 1317.776256] spi-tegra114 3210000.spi: Error in Transfer
[ 1317.776269] spi_master spi0: failed to transfer one message from queue
[ 1317.776306] spi-tegra114 3210000.spi: SPI_ERR: DMA_CTL: 0x00000000, TRANS_STS: 0x40ff0000
