DoF lens shader
In this post [url]https://devtalk.nvidia.com/default/topic/934102/optix/optix-rays-vs-pixels-multiple-rays-pixel-/[/url]
I found a “Depth-Of-Field” (Dof) Sample, which seems to be removed in newer OptiX SDKs.
In my pathtracer engine (based on Detlef’s OptiX Advanced Introduction samples) I simply tried to add it as DoF lens shader.
for the 4 jitter floats I use 4x (float)rand()/(float)RAND_MAX and update on each accumulation frame.
(I also tried different random numbers for each pixel using rng(…); but no visible difference)
The focal scale I calculate also on host using a focal distance parameter. Camera W is used from the camera update.
In my test I set:
aperture= 0.05
focal distance= 0.0
I assumed, that the near area would be in focus then. But it isn’t… (Its the opposite) And some horizontal artefacts occur. (see attachment)
What I did misundertand and what could be wrong?
Unfortunately the pre-compiled version of the “cook” sample does not work on my system. Is there a newer sample?
Thanx for any help!
my system: Win10PRO 64bit VS2019 Community CUDA 10.0 driver 431.36 OptiX 6.0.0 GTX 1050 2GB
I wouldn’t use the Windows rand() function in a progressive ray tracer at all. RAND_MAX is 32767 which means there are only 15 bits in that RNG.
I had implemented a simple thin lens camera for depth of field as a callable program before. The code below is from a different application than the OptiX Introduction samples, but there should be no problem to add it to the OptiX introduction samples.
Make sure to add a new LENS_SHADER_THIN_LENS enum, add the callable program to the map of programs and adjust the GUI to make it selectable.
// TODO: Add this to the lens_shaders.cu
// Let the sensor be 35 mm wide. Scene is defined in meters!
#define SENSOR_WIDTH 0.035f
// .x = lensRadius
// .y = sensorDistance
// .z = (focalDistance + sensorDistance) / sensorDistance
// .w = aspect ratio == length(sysCameraU) / length(sysCameraV)
rtDeclareVariable(float4, sysThinLens, , );
// TODO: Adjust the signature to the OptiX Introduction, returning origin and direction instead of setting the prd.pos and prd.wi.
RT_CALLABLE_PROGRAM void lens_shader_thinlens(PerRayData& prd, const float2 pixel, const float2 screen, const float2 sample)
  const float2 fragment = pixel + sample;                    // Jitter the sub-pixel location
  const float2 ndc      = (fragment / screen) * 2.0f - 1.0f; // Normalized device coordinates in range [-1, 1].
  // First calculate the point on the lens through which we look.
  const float theta = 2.0f * M_PIf * sample.x;
  const float r     = sqrtf(sample.y) * sysThinLens.x; // sysThinLens.x is the lens radius.
  const float3 lens = make_float3(r * cosf(theta), r * -sinf(theta), 0.0f);
  // Compute the point on the sensor, behind the lens.
  const float3 sensor = make_float3(-ndc.x * SENSOR_WIDTH * sysThinLens.w,
                                    -ndc.y * SENSOR_WIDTH,
                                    -sysThinLens.y);
  // Compute point on the focal plane.
  const float3 focal = (sensor - sysThinLens.z * sensor) - lens;
  const float3 U = optix::normalize(sysCameraU);
  const float3 V = optix::normalize(sysCameraV);
  const float3 W = optix::normalize(sysCameraW); // DAR PERF Do this inside the host code when this camera type is selected.
  prd.pos = sysCameraPosition + lens.x * U + lens.y * V; // + lens.z * W; // lens.z is 0.0f
  prd.wi  = optix::normalize(focal.x * U + focal.y * V + focal.z * W);
// TODO: Host code which fills in the sysThinLens pre-calculated parameters.
// GUI Variables controlling the thin lens camera:
float m_cameraFocalLength;
float m_cameraAperture;
// Defaults:
, m_cameraFocalLength(100.0f) // GUI is in mm, will be sent in meters to match the model coordinates.
, m_cameraAperture(32.0f) // Range [1.0, 64.0f]!
void Application::updateThinLens()
  // Thin lens data:
  float f = (m_cameraAperture - 1.0f) / 63.0f; // (64.0f - 1.0f); // Immediate values 1.0f and 64.0f are from the aperture GUI range!
  f = f * f * 63.0f + 1.0f;  // f = powf((m_cameraAperture - 1.0f) / (64.0f - 1.0f), 2.0f) * (64.0f - 1.0f) + 1.0f;
  const float focalLength = m_cameraFocalLength * 0.001f; // GUI focal length is in millimeters, but the scene is modeled in meters!
  const float lensRadius  = 0.5f * focalLength / f;       // sysThinLens.x
  const float cameraFocalDistance = m_pinholeCamera.m_distance; // Distance in meters.
  const float focalDistance = std::max(focalLength + 0.001f, cameraFocalDistance);  // Set a minimum focal distance bigger than the focalLength.
  const float sensorDistance = 1.0f / (1.0f / focalLength - 1.0f / focalDistance);  // sysThinLens.y
  const float t = (cameraFocalDistance + sensorDistance) / sensorDistance;          // sysThinLens.z
  const float aspect = m_pinholeCamera.getAspectRatio();                            // sysThinLens.w
  m_context["sysThinLens"]->setFloat(lensRadius, sensorDistance, t, aspect);
The pinhole camera distance from the center of interest defines the focus plane. I added an event handler which affects only that distance. Something like CTRL + Right Mouse Button Drag or the like. Have fun.
Thank you very much!
I applied it to the optixIntro_09 scene and used the “focus()” method in the PinholeCamera class as event handler.
I also added it successfully to my main application.
Great fun!
