(Not sure if this is the right place to ask, if not , please kindly point out the right place or person)
I have a connect-3 CX354a installed on my Window Server 2016, and enabled SR-IOV on the card and the server, following the WinOF user guide.
On the ubuntu 18.02 VM created using MS Hyperv-v, I can see the mlnx VF working properly. But when I tried to run testpmd on the VM using the following command:
./testpmd -l 0-1 -n 4 --vdev=net_vdev_netvsc0,iface=eth1,force=1 -w 0002:00:02.0 --vdev=net_vdev_netvsc0,iface=eth2,force=1 -w 0003:00:02.0 – --rxq=2 --txq=2 -i
I ran into an error:
PMD: mlx4.c:138: mlx4_dev_start(): 0x562bff05e040: cannot attach flow rules (code 12, “Cannot allocate memory”), flow error type 2, cause 0x7f39ef408780, message: flow rule rejected by device
The command format was suggested by MS Azure to run DPDK on their AN-enabled VMs. And it does work on Azure VMs.
Here is ibv_devinfo output from my vm:
root@myVM:~/MLNX_OFED_SRC-4.4-1.0.0.0# ibv_devinfo
hca_id: mlx4_0
transport: InfiniBand (0)
fw_ver: 2.42.5000
node_guid: 0014:0500:691f:c3fa
sys_image_guid: ec0d:9a03:001c:92e3
vendor_id: 0x02c9
vendor_part_id: 4100
hw_ver: 0x0
board_id: MT_1090120019
phys_port_cnt: 1
port: 1
state: PORT_DOWN (1)
max_mtu: 4096 (5)
active_mtu: 1024 (3)
sm_lid: 0
port_lid: 0
port_lmc: 0x00
link_layer: Ethernet
hca_id: mlx4_1
fw_ver: 2.42.5000
node_guid: 0014:0500:76e0:b9d1
vendor_id: 0x02c9
hw_ver: 0x0
phys_port_cnt: 1
port: 1
max_mtu: 4096 (5)
sm_lid: 0
port_lid: 0
port_lmc: 0x00
and here is the kernel module info of mlx4_en:
filename: /lib/modules/4.15.0-23-generic/updates/dkms/mlx4_en.koversion: 4.4-1.0.0license: Dual BSD/GPLdescription:Mellanox ConnectX HCA Ethernet driverauthor: Liran Liss, Yevgeny Petrilinsrcversion: 23E8E7A25194AE68387DC95depends: mlx4_core,mlx_compat,ptp,devlinkretpoline: Yname: mlx4_envermagic: 4.15.0-23-generic SMP mod_unload parm: udev_dev_port_dev_id:Work with dev_id or dev_port when supported by the kernel. Range: 0 <= udev_dev_port_dev_id <= 2 (default = 0). 0: Work with dev_port if supported by the kernel, otherwise work with dev_id. 1: Work only with dev_id regardless of dev_port support. 2: Work with both of dev_id and dev_port (if dev_port is supported by the kernel). (int)parm: udp_rss:Enable RSS for incoming UDP traffic or disabled (0) (uint)parm: pfctx:Priority based Flow Control policy on TX[7:0]. Per priority bit mask (uint)parm: pfcrx:Priority based Flow Control policy on RX[7:0]. Per priority bit mask (uint)parm: inline_thold:Threshold for using inline data (range: 17-104, default: 104) (uint)
One difference I notice between my local VM and Azure VM is that the mlx4_en.ko module is definitely different. Azure seems to be using a specialized version of mlx4_en. Is this the reason why the testpmd works on azure but not my local Hyper-v VM?
If so, how can I get a DPDK-capable driver for MS Hyper-v?
Thank you!
