Dear Steve,
My Drive PX2 is running with DriveInstall_4.1.8.0L_SDK_b43.run software package.
I am setting up my system for hybrid-cross-compilation using NFS. I have already setup a private LAN between the Target(dpx2) and my Host. However, the I got the following error while flashing the files from my host to NFS
question1) ./bootburn.sh script aborted with the an error msg “There is no supported for specifying kernel-dtb with Hypervisor”. Why is this happening?
user@kickseed:~/NVIDIA/FIRMWARE/DOWNLOAD/VibranteSDK/vibrante-t186ref-foundation/utils/scripts/bootburn$ ./bootburn.sh -b p2379c01-t186a -d kernel-dtb tegra186-vcm31-p2379-0000-c01-00-base-a-air-cooled.dtb
Successfully acquired lock over /var/lock/LCK…bootburn
[sudo] password for user:
Here I am providing the full details about the steps that I have followed.
Full Details:
- I have verified the existence of the targetfs in my host
user@kickseed:~/NVIDIA/FIRMWARE/DOWNLOAD/VibranteSDK/vibrante-t186ref-linux$ ls
bin-target kernel-rt_patches nvpmodel targetfs-pkgs
data lib-target oss ubuntu-rootfs-licenses.txt
include make samples utils
kernel modules targetfs vulkan_icd
- Connect Target to the host via USB-to-Ethernet dongle type adaptor. An interface eth1 is already consumed by the host, therefore, I am using eth2 for my private LAN
user@kickseed:~$ cat /etc/network/interfaces
This file describes the network interfaces available on your system # and how to activate them. For more information, see interfaces(5).
The loopback network interface
auto lo iface lo inet loopback
auto eth2 allow-hotplug eth2
iface eth2 inet static
address 10.0.0.1
netmask 255.255.255.0
post-up /etc/init.d/isc-dhcp-server restart
user@kickseed:~$
Restart the host networking with the following command sudo /etc/init.d/networking restart
I am skipping the section “DRIVE PX 2 10-Gigabit Ethernet Ownership”. This is because, I do not want to switch the ownership
Configure the DHCP server on the host
user@kickseed:~$ sudo apt-get install isc-dhcp-server
user@kickseed:~$ cat /etc/default/isc-dhcp-server
… INTERFACES=“eth2”
user@kickseed:~$
user@kickseed:~$ cat /etc/dhcp/dhcpd.conf
ddns-update-style none;
allow bootp;
subnet 10.0.0.0 netmask 255.255.255.0 {
option routers 10.0.0.1;
option domain-name “corp.quanergy.com” ;
option domain-name-servers 10.1.10.8 ;
default-lease-time 345600;
max-lease-time 31557600;
range 10.0.0.2 10.0.0.254;
option root-path “10.0.0.1:/home/user/NVIDIA/FIRMWARE/DOWNLOAD/VibranteSDK/vibrante-t186ref-linux/targetfs,wsize=8192,rsize=8192,v3”;
Restart the dhcp server by running the below command
sudo /etc/init.d/isc-dhcp-server restart
Modified the working copy of the bootburn configuration file with the following line
os_args=“root=/dev/nfs nfsdev=usb0 console=ttyS0,115200n8”
Following is a list of files that has defined the or_args. So, I need to modify all these files.
(quickboot_emmc_linux_initramfs_p3310.cfg, quickboot_qspi_linux_initramfs_e2681.cfg, quickboot_qspi_linux_initramfs.cfg, quickboot_qspi_rt_linux_initramfs.cfg, quickboot_emmc_linux_initramfs.cfg, quickboot_qspi_linux_initramfs_bali.cfg)
- I have setup the NFS server and restarted it.
user@kickseed:~$ sudo exportfs /home/user/NVIDIA/FIRMWARE/DOWNLOAD/VibranteSDK/vibrante-t186ref-linux/targetfs user@kickseed:~$
- Internet access is enabled. I can ping from target to host’s private IP and vice versa
nvidia@nvidia:~$ ping 10.0.0.1
PING 10.0.0.1 (10.0.0.1) 56(84) bytes of data. 64 bytes from 10.0.0.1: icmp_seq=1 ttl=64 time=0.405 ms user@kickseed:~$ ping 10.0.0.3
PING 10.0.0.3 (10.0.0.3) 56(84) bytes of data. 64 bytes from 10.0.0.3: icmp_seq=1 ttl=64 time=0.352 ms
- Target routing table
nvidia@nvidia:~$ route -n
Kernel IP routing table
Destination Gateway Genmask Flags Metric Ref Use Iface
0.0.0.0 10.1.11.1 0.0.0.0 UG 1024 0 0 enp3s0
0.0.0.0 10.0.0.1 0.0.0.0 UG 1024 0 0 eth0
10.0.0.0 0.0.0.0 255.255.255.0 U 0 0 0 eth0
10.0.0.1 0.0.0.0 255.255.255.255 UH 1024 0 0 eth0
10.1.11.0 0.0.0.0 255.255.255.0 U 0 0 0 enp3s0
10.1.11.1 0.0.0.0 255.255.255.255 UH 1024 0 0 enp3s0
10.42.0.0 0.0.0.0 255.255.255.0 U 0 0 0 eth0.200
nvidia@nvidia:~$
- Host routing table
user@kickseed:~$ route -n
0.0.0.0 10.1.11.1 0.0.0.0 UG 0 0 0 eth1
10.0.0.0 0.0.0.0 255.255.255.0 U 0 0 0 eth2
10.1.11.0 0.0.0.0 255.255.255.0 U 1 0 0 eth1
169.254.0.0 0.0.0.0 255.255.0.0 U 1000 0 0 eth2
user@kickseed:~$
I have forced Tegra A in recovery mode (via minicom)
I am flashing the board from my host. However, I got the following error.
Successfully acquired lock over /var/lock/LCK…bootburn [sudo] password for user: There is no supported for specifying kernel-dtb with Hypervisor
Please note I am not using any virtual-machine or hypervisor. I am using a ubuntu 16.04 native machine as my host. But the error seems to be indicating the some issues with the Hypervisor ???
Sam
