Hi.
I have the Tesla D870 connected to a machine with a Vista 64 OS.
Installation of the new driver (180.60 beta / 64bit) goes smoothly.
The strange thing is that now only one of the Tesla C870 inside the D870 is recognized as a cuda device.
The other one is not recognized.
The really strange thing is that GPUZ and other utilities show the two C870s to be really different from each other. Different speeds, different GPU clocks etc.
They appears as different GPUs on XP32bit as well but on the 32 bit system they are both identified as CUDA devices anyhow.
This is a screenshot from deviceQuery from the SDK showing that only one C870 is recognized: External Media
This is a side-by-side screenshot from gpuz showing how different the cards are from each other. Is this relevant to the problem at hand? External Media
This is a screenshot from the NVIDIA control panel System Information showing how one C870 is being recognized a part of D870 and the other one is left out… Strange: External Media
What do I do…?
Is this just a bad side effect of the BETA version drivers, a mere bug, or is this a problem with my Tesla device?
Notice that MisterAnderson42 suffered/suffers from the same Two-C870-Are-Reported-With-Different-Bandwidth issue, from there one may deduce that it is a driver issue. Perhaps not unique to Vista. What’s unique to vista (hence this thread is still alive in this forum as well) is the fact that only one C870 is being recognized as a cuda device (while in WinXP they are both recognized as CUDA devices) This suggests that this is rather a driver issue than a hardware issue, no?.
But they have already solved the first. And how are you certain that the 2nd is a bug? Have you even checked the release notes to look for known issues? Or read other posts on this forum?
First of all, Mr. Anderson, it’s definitely a bug because everything works fine under XP but not under Vista. Both OSs had similar problems and the new driver only fixed the WinXP and not the Vista. So again, this is a bug. and they didn’t “already solved the first”, as you put it.
As for Physx, Very interesting thing here: Under XP Physx is disabled and everything is working fine. Under Vista 64, Physx is enabled for one of the Tesla C870 and when I disable it (for it to have the same settings as the XP machine) then… No C870 are identified at all as CUDA capable. Same thing goes when I enable the Physx for my Geforce 8600GT.
