Hi all,
I’m working on a realtime kernel and I absolutely need the GPU for some deep-learning stuff.
None of the default drivers will work on realtime.
The patch tutorial I found didn’t work because the new driver versions don’t follow the same structure as before.
Can anyone point me to the right direction, please?
Last time I heard of efforts getting the nvidia propr. driver to work with a RT kernel is about 2 years ago so I suspect anything you can find on the web is outdated and you’re pretty much on your own to start something new.
That said, does the driver even compile, for a start?
It doesn’t compile due to the realtime issue. The installation complains about that and quits.
