I have Nvidia driver 470.223.02 for Linux, which should work with GeForce GT 710, but nvidia-smi
shows N/A
for its power consumption, utilization, and running processes. Meanwhile, the P40 cards show up correctly.
Moreover, the overclocking options in GreenWithEnvy are also greyed out, which I suspect is a driver-related issue. How do I fix that?
nvidia-bug-report.log.gz (742.5 KB)
$ nvidia-smi -L
GPU 0: Tesla P40 (UUID: GPU-ac45b921-3664-d911-5dd7-e5b8d49551c3)
GPU 1: Tesla P40 (UUID: GPU-11fdf0e4-2c22-162a-a65e-f594c9a908ae)
GPU 2: NVIDIA GeForce GT 710 (UUID: GPU-6fabed11-9de9-cd98-3220-658b45c1e7e8)
$ nvidia-smi
Mon Feb 19 19:14:14 2024
| NVIDIA-SMI 470.223.02 Driver Version: 470.223.02 CUDA Version: 11.4 |
| | | MIG M. |
| 0 Tesla P40 On | 00000000:04:00.0 Off | Off |
| N/A 26C P8 9W / 250W | 0MiB / 24451MiB | 0% Default |
| | | N/A |
| 1 Tesla P40 On | 00000000:42:00.0 Off | Off |
| N/A 27C P8 9W / 250W | 0MiB / 24451MiB | 0% Default |
| | | N/A |
| 2 NVIDIA GeForce ... On | 00000000:44:00.0 N/A | N/A |
| 50% 28C P8 N/A / N/A | 1MiB / 2002MiB | N/A Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| No running processes found |
$ nvidia-smi -q
==============NVSMI LOG==============
Timestamp : Mon Feb 19 19:26:21 2024
Driver Version : 470.223.02
CUDA Version : 11.4
Attached GPUs : 3
GPU 00000000:04:00.0
Product Name : Tesla P40
Product Brand : Tesla
Display Mode : Enabled
Display Active : Disabled
Persistence Mode : Enabled
MIG Mode
Current : N/A
Pending : N/A
Accounting Mode : Disabled
Accounting Mode Buffer Size : 4000
Driver Model
Current : N/A
Pending : N/A
Serial Number : 0322518166720
GPU UUID : GPU-ac45b921-3664-d911-5dd7-e5b8d49551c3
Minor Number : 0
VBIOS Version : 86.02.23.00.00
MultiGPU Board : No
Board ID : 0x400
GPU Part Number : 900-2G610-0000-000
Module ID : 0
Inforom Version
Image Version : G610.0200.00.03
OEM Object : 1.1
ECC Object : 4.1
Power Management Object : N/A
GPU Operation Mode
Current : N/A
Pending : N/A
GSP Firmware Version : N/A
GPU Virtualization Mode
Virtualization Mode : None
Host VGPU Mode : N/A
IBMNPU
Relaxed Ordering Mode : N/A
PCI
Bus : 0x04
Device : 0x00
Domain : 0x0000
Device Id : 0x1B3810DE
Bus Id : 00000000:04:00.0
Sub System Id : 0x11D910DE
GPU Link Info
PCIe Generation
Max : 3
Current : 1
Link Width
Max : 16x
Current : 16x
Bridge Chip
Type : N/A
Firmware : N/A
Replays Since Reset : 0
Replay Number Rollovers : 0
Tx Throughput : 0 KB/s
Rx Throughput : 0 KB/s
Fan Speed : N/A
Performance State : P8
Clocks Throttle Reasons
Idle : Not Active
Applications Clocks Setting : Not Active
SW Power Cap : Active
HW Slowdown : Not Active
HW Thermal Slowdown : Not Active
HW Power Brake Slowdown : Not Active
Sync Boost : Not Active
SW Thermal Slowdown : Not Active
Display Clock Setting : Not Active
FB Memory Usage
Total : 24451 MiB
Used : 0 MiB
Free : 24451 MiB
BAR1 Memory Usage
Total : 32768 MiB
Used : 2 MiB
Free : 32766 MiB
Compute Mode : Default
Utilization
Gpu : 0 %
Memory : 0 %
Encoder : 0 %
Decoder : 0 %
Encoder Stats
Active Sessions : 0
Average FPS : 0
Average Latency : 0
FBC Stats
Active Sessions : 0
Average FPS : 0
Average Latency : 0
Ecc Mode
Current : Disabled
Pending : Disabled
ECC Errors
Volatile
Single Bit
Device Memory : N/A
Register File : N/A
L1 Cache : N/A
L2 Cache : N/A
Texture Memory : N/A
Texture Shared : N/A
CBU : N/A
Total : N/A
Double Bit
Device Memory : N/A
Register File : N/A
L1 Cache : N/A
L2 Cache : N/A
CBU : N/A
Total : N/A
Aggregate
Single Bit
Device Memory : N/A
Register File : N/A
L1 Cache : N/A
L2 Cache : N/A
CBU : N/A
Total : N/A
Double Bit
Device Memory : N/A
Register File : N/A
L1 Cache : N/A
L2 Cache : N/A
CBU : N/A
Total : N/A
Retired Pages
Single Bit ECC : 0
Double Bit ECC : 0
Pending Page Blacklist : No
Remapped Rows : N/A
Temperature
GPU Current Temp : 26 C
GPU Shutdown Temp : 95 C
GPU Slowdown Temp : 92 C
GPU Max Operating Temp : N/A
GPU Target Temperature : N/A
Memory Current Temp : N/A
Memory Max Operating Temp : N/A
Power Readings
Power Management : Supported
Power Draw : 9.84 W
Power Limit : 250.00 W
Default Power Limit : 250.00 W
Enforced Power Limit : 250.00 W
Min Power Limit : 125.00 W
Max Power Limit : 250.00 W
Clocks
Graphics : 544 MHz
SM : 544 MHz
Memory : 405 MHz
Video : 544 MHz
Applications Clocks
Graphics : 1531 MHz
Memory : 3615 MHz
Default Applications Clocks
Graphics : 1303 MHz
Memory : 3615 MHz
Max Clocks
Graphics : 1531 MHz
SM : 1531 MHz
Memory : 3615 MHz
Video : 1379 MHz
Max Customer Boost Clocks
Graphics : 1531 MHz
Clock Policy
Auto Boost : N/A
Auto Boost Default : N/A
Voltage
Graphics : N/A
Processes : None
GPU 00000000:42:00.0
MIG Mode
Current : N/A
Pending : N/A
Driver Model
Current : N/A
Pending : N/A
Serial Number : 0322518167163
GPU UUID : GPU-11fdf0e4-2c22-162a-a65e-f594c9a908ae
Minor Number : 1
MultiGPU Board : No
Board ID : 0x4200
Module ID : 0
Inforom Version
OEM Object : 1.1
ECC Object : 4.1
GPU Operation Mode
Current : N/A
Pending : N/A
IBMNPU
PCI
Bus : 0x42
Device : 0x00
Domain : 0x0000
Bus Id : 00000000:42:00.0
GPU Link Info
PCIe Generation
Max : 3
Current : 1
Link Width
Max : 16x
Current : 16x
Bridge Chip
Type : N/A
Firmware : N/A
Fan Speed : N/A
Idle : Not Active
FB Memory Usage
Total : 24451 MiB
Used : 0 MiB
Free : 24451 MiB
BAR1 Memory Usage
Total : 32768 MiB
Used : 2 MiB
Free : 32766 MiB
Utilization
Gpu : 0 %
Memory : 0 %
Encoder : 0 %
Decoder : 0 %
Encoder Stats
Active Sessions : 0
Average FPS : 0
Average Latency : 0
FBC Stats
Active Sessions : 0
Average FPS : 0
Average Latency : 0
Ecc Mode
Current : Disabled
Pending : Disabled
ECC Errors
Volatile
Single Bit
Device Memory : N/A
Register File : N/A
L1 Cache : N/A
L2 Cache : N/A
CBU : N/A
Total : N/A
Double Bit
Device Memory : N/A
Register File : N/A
L1 Cache : N/A
L2 Cache : N/A
CBU : N/A
Total : N/A
Aggregate
Single Bit
Device Memory : N/A
Register File : N/A
L1 Cache : N/A
L2 Cache : N/A
CBU : N/A
Total : N/A
Double Bit
Device Memory : N/A
Register File : N/A
L1 Cache : N/A
L2 Cache : N/A
CBU : N/A
Total : N/A
Retired Pages
Single Bit ECC : 0
Double Bit ECC : 0
Remapped Rows : N/A
Temperature
GPU Current Temp : 28 C
Power Readings
Power Draw : 9.83 W
Clocks
Graphics : 544 MHz
SM : 544 MHz
Memory : 405 MHz
Video : 544 MHz
Applications Clocks
Graphics : 1531 MHz
Memory : 3615 MHz
Graphics : 1303 MHz
Memory : 3615 MHz
Max Clocks
Graphics : 1531 MHz
SM : 1531 MHz
Memory : 3615 MHz
Video : 1379 MHz
Graphics : 1531 MHz
Clock Policy
Auto Boost : N/A
Voltage
Graphics : N/A
Processes : None
GPU 00000000:44:00.0
Product Name : NVIDIA GeForce GT 710
Product Brand : GeForce
Display Mode : N/A
Display Active : N/A
MIG Mode
Current : N/A
Pending : N/A
Accounting Mode : N/A
Accounting Mode Buffer Size : N/A
Driver Model
Current : N/A
Pending : N/A
Serial Number : N/A
GPU UUID : GPU-6fabed11-9de9-cd98-3220-658b45c1e7e8
Minor Number : 2
VBIOS Version : 80.28.A6.00.5F
MultiGPU Board : N/A
Board ID : N/A
GPU Part Number : N/A
Module ID : 0
Inforom Version
Image Version : N/A
OEM Object : N/A
ECC Object : N/A
GPU Operation Mode
Current : N/A
Pending : N/A
Virtualization Mode : N/A
IBMNPU
PCI
Bus : 0x44
Device : 0x00
Domain : 0x0000
Device Id : 0x128B10DE
Bus Id : 00000000:44:00.0
Sub System Id : 0x8C931462
GPU Link Info
PCIe Generation
Max : N/A
Current : N/A
Link Width
Max : N/A
Current : N/A
Bridge Chip
Type : N/A
Firmware : N/A
Tx Throughput : N/A
Rx Throughput : N/A
Fan Speed : 50 %
Clocks Throttle Reasons : N/A
FB Memory Usage
Total : 2002 MiB
Used : 1 MiB
Free : 2001 MiB
BAR1 Memory Usage
Total : N/A
Used : N/A
Free : N/A
Utilization
Gpu : N/A
Memory : N/A
Encoder : N/A
Decoder : N/A
Encoder Stats
Active Sessions : N/A
Average FPS : N/A
Average Latency : N/A
FBC Stats
Average FPS : N/A
Ecc Mode
Current : N/A
Pending : N/A
ECC Errors
Volatile
Single Bit
Device Memory : N/A
Register File : N/A
L1 Cache : N/A
L2 Cache : N/A
CBU : N/A
Total : N/A
Double Bit
Device Memory : N/A
Register File : N/A
L1 Cache : N/A
L2 Cache : N/A
CBU : N/A
Total : N/A
Aggregate
Single Bit
Device Memory : N/A
Register File : N/A
L1 Cache : N/A
L2 Cache : N/A
CBU : N/A
Total : N/A
Double Bit
Device Memory : N/A
Register File : N/A
L1 Cache : N/A
L2 Cache : N/A
CBU : N/A
Total : N/A
Retired Pages
Single Bit ECC : N/A
Double Bit ECC : N/A
Pending Page Blacklist : N/A
Remapped Rows : N/A
Temperature
GPU Shutdown Temp : N/A
GPU Slowdown Temp : N/A
Power Readings
Power Management : N/A
Power Draw : N/A
Power Limit : N/A
Default Power Limit : N/A
Enforced Power Limit : N/A
Min Power Limit : N/A
Max Power Limit : N/A
Clocks
Graphics : N/A
SM : N/A
Memory : N/A
Video : N/A
Applications Clocks
Graphics : 954 MHz
Memory : 800 MHz
Graphics : 954 MHz
Memory : 800 MHz
Max Clocks
Graphics : N/A
SM : N/A
Memory : N/A
Video : N/A
Graphics : N/A
Clock Policy
Auto Boost : N/A
Voltage
Graphics : N/A
Processes : None
