How to set Tesla P40 as default GPU
Hi everyone !
We have an issue with our Tesla P40.
We have buy a used Dell R7525 with an Tesla P40 and have installed Proxmox and configured for PCI Passthrough.
We have configured a VM with the Tesla P40, installed Windows 2022 Standard Evaluation with Remote Desktop Session Host.
In our test with 15 concurrent users, every users was able to use the Tesla for 3D or video decoding like Youtube.
After that, we have moved our production VM, an Windows 2022 Standard with RDSH, from old ESXi server to Proxmox, but the Tesla P40 didn’t work as expected.
The Tesla P40 are detected by Windows, Grid drivers are installed correctly, there are no error in the device manager.
The Tesla P40 are not used by default.
If we tell Windows to use the Tesla P40 for a specific application (in Graphics settings), it’s work.
We have try to disable default GPU, set display to none in Proxmox, nothing change.
Is there a way to use the Tesla P40 as default GPU for any applications and all users ?
Thank you
Here is some more info with command line : nvidia-smi -q
I see on the working VM, the GPU Virtualization Mode is Pass-Through
On the non working VM, the GPU Virtualization Mode is None
Both VM run on the same Proxmox host, there are 2 nVidia Tesla P40 in the host
This is the output from a TS server where an nVidia Tesla P40 work
==============NVSMI LOG==============
Timestamp                                 : Thu Jun 20 10:14:03 2024
Driver Version                            : 537.13
CUDA Version                              : 12.2
Attached GPUs                             : 1
GPU 00000000:01:00.0
    Product Name                          : Tesla P40
    Product Brand                         : Tesla
    Product Architecture                  : Pascal
    Display Mode                          : Enabled
    Display Active                        : Disabled
    Persistence Mode                      : N/A
    Addressing Mode                       : N/A
    MIG Mode
        Current                           : N/A
        Pending                           : N/A
    Accounting Mode                       : Disabled
    Accounting Mode Buffer Size           : 4000
    Driver Model
        Current                           : WDDM
        Pending                           : WDDM
    Serial Number                         : ...
    GPU UUID                              : ...
    Minor Number                          : N/A
    VBIOS Version                         : 86.02.23.00.00
    MultiGPU Board                        : No
    Board ID                              : 0x100
    Board Part Number                     : 900-1G610-0030-000
    GPU Part Number                       : 1B38-895-A1
    FRU Part Number                       : N/A
    Module ID                             : 1
    Inforom Version
        Image Version                     : G610.0300.00.01
        OEM Object                        : 1.1
        ECC Object                        : 4.1
        Power Management Object           : N/A
    GPU Operation Mode
        Current                           : N/A
        Pending                           : N/A
    GSP Firmware Version                  : N/A
        Virtualization Mode               : **Pass-Through**
        Host VGPU Mode                    : N/A
    vGPU Software Licensed Product
        Product Name                      : NVIDIA Virtual Applications
        License Status                    : Licensed
    GPU Reset Status
        Reset Required                    : No
        Drain and Reset Recommended       : N/A
    IBMNPU
        Relaxed Ordering Mode             : N/A
    PCI
        Bus                               : 0x01
        Device                            : 0x00
        Domain                            : 0x0000
        Device Id                         : 0x1B3810DE
        Bus Id                            : 00000000:01:00.0
        Sub System Id                     : 0x11D910DE
        GPU Link Info
            PCIe Generation
                Max                       : 3
                Current                   : 3
                Device Current            : 3
                Device Max                : 3
                Host Max                  : **N/A**
            Link Width
                Max                       : 16x
                Current                   : 16x
        Bridge Chip
            Type                          : N/A
            Firmware                      : N/A
        Replays Since Reset               : 0
        Replay Number Rollovers           : 0
        Tx Throughput                     : 0 KB/s
        Rx Throughput                     : 24000 KB/s
        Atomic Caps Inbound               : N/A
        Atomic Caps Outbound              : N/A
    Fan Speed                             : N/A
    Performance State                     : P8
    Clocks Event Reasons
        Idle                              : Active
        Applications Clocks Setting       : Not Active
        SW Power Cap                      : Not Active
        HW Slowdown                       : Not Active
            HW Thermal Slowdown           : Not Active
            HW Power Brake Slowdown       : Not Active
        Sync Boost                        : Not Active
        SW Thermal Slowdown               : Not Active
        Display Clock Setting             : Not Active
    FB Memory Usage
        Total                             : 24576 MiB
        Reserved                          : 307 MiB
        Used                              : 155 MiB
        Free                              : 24113 MiB
    BAR1 Memory Usage
        Total                             : 32768 MiB
        Used                              : 2 MiB
        Free                              : 32766 MiB
    Conf Compute Protected Memory Usage
        Total                             : N/A
        Used                              : N/A
        Free                              : N/A
    Compute Mode                          : Default
    Utilization
        Gpu                               : 2 %
        Memory                            : 0 %
        Encoder                           : 0 %
        Decoder                           : 0 %
        JPEG                              : N/A
        OFA                               : N/A
    Encoder Stats
        Active Sessions                   : 0
        Average FPS                       : 0
        Average Latency                   : 0
    FBC Stats
        Active Sessions                   : 0
        Average FPS                       : 0
        Average Latency                   : 0
    ECC Mode
        Current                           : Disabled
        Pending                           : Disabled
    ECC Errors
        Volatile
            Single Bit
                Device Memory             : N/A
                Register File             : N/A
                L1 Cache                  : N/A
                L2 Cache                  : N/A
                Texture Memory            : N/A
                Texture Shared            : N/A
                CBU                       : N/A
                Total                     : N/A
            Double Bit
                Device Memory             : N/A
                Register File             : N/A
                L1 Cache                  : N/A
                L2 Cache                  : N/A
                CBU                       : N/A
                Total                     : N/A
        Aggregate
            Single Bit
                Device Memory             : N/A
                Register File             : N/A
                L1 Cache                  : N/A
                L2 Cache                  : N/A
                CBU                       : N/A
                Total                     : N/A
            Double Bit
                Device Memory             : N/A
                Register File             : N/A
                L1 Cache                  : N/A
                L2 Cache                  : N/A
                CBU                       : N/A
                Total                     : N/A
    Retired Pages
        Single Bit ECC                    : 0
        Double Bit ECC                    : 0
        Pending Page Blacklist            : No
    Remapped Rows                         : N/A
    Temperature
        GPU Current Temp                  : 23 C
        GPU T.Limit Temp                  : N/A
        GPU Shutdown Temp                 : 95 C
        GPU Slowdown Temp                 : 92 C
        GPU Max Operating Temp            : N/A
        GPU Target Temperature            : N/A
        Memory Current Temp               : N/A
        Memory Max Operating Temp         : N/A
    GPU Power Readings
        Power Draw                        : 14.09 W
        Current Power Limit               : 250.00 W
        Requested Power Limit             : 250.00 W
        Default Power Limit               : 250.00 W
        Min Power Limit                   : 125.00 W
        Max Power Limit                   : 250.00 W
    Module Power Readings
        Power Draw                        : N/A
        Current Power Limit               : N/A
        Requested Power Limit             : N/A
        Default Power Limit               : N/A
        Min Power Limit                   : N/A
        Max Power Limit                   : N/A
    Clocks
        Graphics                          : 544 MHz
        SM                                : 544 MHz
        Memory                            : 405 MHz
        Video                             : 544 MHz
    Applications Clocks
        Graphics                          : 1303 MHz
        Memory                            : 3615 MHz
    Default Applications Clocks
        Graphics                          : 1303 MHz
        Memory                            : 3615 MHz
    Deferred Clocks
        Memory                            : N/A
    Max Clocks
        Graphics                          : 1531 MHz
        SM                                : 1531 MHz
        Memory                            : 3615 MHz
        Video                             : 1379 MHz
    Max Customer Boost Clocks
        Graphics                          : 1531 MHz
    Clock Policy
        Auto Boost                        : N/A
        Auto Boost Default                : N/A
    Voltage
        Graphics                          : N/A
    Fabric
        State                             : N/A
        Status                            : N/A
    Processes
And the output from a TS server where the card doesn’t work
Timestamp                                 : Thu Jun 20 10:12:05 2024
CUDA Version                              : 12.2
Attached GPUs                             : 1
    MIG Mode
        Current                           : N/A
        Pending                           : N/A
    Driver Model
        Current                           : WDDM
        Pending                           : WDDM
    Serial Number                         : ...
    GPU UUID                              : ...
    Minor Number                          : N/A
    MultiGPU Board                        : No
    Board ID                              : 0x100
    Board Part Number                     : 690-1G610-0300-000
    Module ID                             : 1
    Inforom Version
        OEM Object                        : 1.1
        ECC Object                        : 4.1
    GPU Operation Mode
        Current                           : N/A
        Pending                           : N/A
        Virtualization Mode               : **None**
    GPU Reset Status
        Reset Required                    : No
    IBMNPU
    PCI
        Bus                               : 0x01
        Device                            : 0x00
        Domain                            : 0x0000
        GPU Link Info
            PCIe Generation
                Max                       : 3
                Current                   : 3
                Device Current            : 3
                Device Max                : 3
                Host Max                  : **4**
            Link Width
                Max                       : 16x
                Current                   : 16x
        Bridge Chip
            Type                          : N/A
            Firmware                      : N/A
        Rx Throughput                     : 0 KB/s
    Fan Speed                             : N/A
        Idle                              : Active
    FB Memory Usage
        Total                             : 24576 MiB
        Reserved                          : 307 MiB
        Used                              : 887 MiB
        Free                              : 23380 MiB
    BAR1 Memory Usage
        Total                             : 32768 MiB
        Used                              : 2 MiB
        Free                              : 32766 MiB
        Total                             : N/A
        Used                              : N/A
        Free                              : N/A
    Utilization
        Gpu                               : 0 %
        Memory                            : 0 %
        Encoder                           : 0 %
        Decoder                           : 0 %
        JPEG                              : N/A
        OFA                               : N/A
    Encoder Stats
        Active Sessions                   : 0
        Average FPS                       : 0
        Average Latency                   : 0
    FBC Stats
        Active Sessions                   : 0
        Average FPS                       : 0
        Average Latency                   : 0
    ECC Mode
        Current                           : Disabled
        Pending                           : Disabled
    ECC Errors
        Volatile
            Single Bit
                Device Memory             : N/A
                Register File             : N/A
                L1 Cache                  : N/A
                L2 Cache                  : N/A
                CBU                       : N/A
                Total                     : N/A
            Double Bit
                Device Memory             : N/A
                Register File             : N/A
                L1 Cache                  : N/A
                L2 Cache                  : N/A
                CBU                       : N/A
                Total                     : N/A
        Aggregate
            Single Bit
                Device Memory             : N/A
                Register File             : N/A
                L1 Cache                  : N/A
                L2 Cache                  : N/A
                CBU                       : N/A
                Total                     : N/A
            Double Bit
                Device Memory             : N/A
                Register File             : N/A
                L1 Cache                  : N/A
                L2 Cache                  : N/A
                CBU                       : N/A
                Total                     : N/A
    Retired Pages
        Single Bit ECC                    : 0
        Double Bit ECC                    : 0
    Remapped Rows                         : N/A
    Temperature
        GPU Current Temp                  : 24 C
    GPU Power Readings
        Power Draw                        : 9.89 W
        Power Draw                        : N/A
    Clocks
        Graphics                          : 544 MHz
        SM                                : 544 MHz
        Memory                            : 405 MHz
        Video                             : 544 MHz
    Applications Clocks
        Graphics                          : 1303 MHz
        Memory                            : 3615 MHz
        Graphics                          : 1303 MHz
        Memory                            : 3615 MHz
    Deferred Clocks
        Memory                            : N/A
    Max Clocks
        Graphics                          : 1531 MHz
        SM                                : 1531 MHz
        Memory                            : 3615 MHz
        Video                             : 1379 MHz
        Graphics                          : 1531 MHz
    Clock Policy
        Auto Boost                        : N/A
    Voltage
        Graphics                          : N/A
    Fabric
        State                             : N/A
        Status                            : N/A
    Processes
I don’t think there will be much help on Proxmox as we don’t support Proxmox as hypervisor yet. Neither would I expect the P40 is supported in the given server! It is crucial to use certified hardware .
Best regards
Simon
Like I say in my first post, the GPU work.
In my test VM, the P40 was used by default for all applications
In me production VM, I need to tell Windows to use the P40
[HKEY_CURRENT_USER\Software\Microsoft\DirectX\UserGpuPreferences]
"C:\\Program Files (x86)\\Microsoft\\Edge\\Application\\msedge.exe"="GpuPreference=2;"
Why do I need to set GpuPreference in the production VM, but not in the test VM ?
Does there are a global parameters to force all applications to use the P40 ?
